Can you use the little spare tire?
Old Apr 27, 2003
MattC1's Avatar
MattC1 is an unknown quantity at this point
I have neuspeed race springs on 17's I was wondering if I were to ever get a flat tire can I use the spare in the trunk? if not then I will remove it, what do you do if you have a flat? can you use that "fix a flat" bottle to get you to a repair shop.. Thanks for the help guys
Old Apr 27, 2003
4bangin's Avatar
ummm, ya you can use the spare. it will drive uneven but you arent supposed to go very far on the spare. it drives uneven on the stock tires too. if you want, just throw a full size spare in your trunk.
and the fix a flat stuff doesnt work if you blowe out a tire or something, which is what you have to worry about with low pro tires. that stuff only works if you get a nail or somehting in it.
Old Apr 27, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
Thats weird...
i was just about to post this question...
I was thinking that if i cant use it on my 17's then i should take it out of the trunk to reduce weight...
Old Apr 28, 2003
MattC1's Avatar
Originally posted by 2k2EXCOUPE
Thats weird...
yea thats what I wanted to know I heard that you can't use the spare if the car has a low drop and is on 17's.
Old Apr 28, 2003
BigDaddyHonda's Avatar
BigDaddyHonda is an unknown quantity at this point
It depends on how low you are dropped & what kind of exhaust you are running.
Mine is dropped over 2" in the rear, and I had to use the temp on the rear passenger side.
There was some scraping of the STOCK exhaust components, but only on really uneven roads or when I was turning into inclined driveways.
If your header or muffler hangs down further than stock, you might have a problem. It's probably worth keeping that little "donut" just so you don't have to be stranded somewhere. As long as your whole exhaust system just gets a few scrapes instead of getting completely torn off!
If you are close to stock ride heighth there shouldn't be much of a problem unless you got some BIG BIG muffler on that car
Old Apr 28, 2003
HondaLuver's Avatar
Its a celebration bitches!
you know what i had my spare on for a day at stock height, and it lowered my cars corner so much that i scraped quite a few times... if your car is slammed or close to it, i don't think it is worth it to have it in your trunk because the tire diameter is so small that you will pretty much be sitting on the floor if you have the spare on and being lowered...
Old Apr 28, 2003
sandman1011's Avatar
sandman1011 is an unknown quantity at this point
Ummm, why not just keep one of the stock tires in the trunk instead of the little dinky spare tire if you upgrade to larger wheels? Wouldn't that be better, except for the extra weight you'd be hauling around?
Old Apr 29, 2003
HondaLuver's Avatar
it wont fit in the trunk...
GotSiR
Jun 23, 2016 04:06 PM
Strycker
Aug 18, 2015 02:25 PM
alaga
25
Aug 13, 2015 04:42 PM
EngiNERD
Aug 12, 2015 09:20 AM
mistermenphis22
Jul 13, 2015 04:43 PM
