Does Type-R strut bar fit on EX without modification?
Old Apr 24, 2003
CivicBR900EX's Avatar
Master
CivicBR900EX is an unknown quantity at this point
Ebay got a whole bunch of these Type-R front strut bar for Civics. Would I need to drill a new hole for the steering fluid bracket on the EX model?
Old Apr 24, 2003
robbclark1's Avatar
Retired suspension supermod.
I don't believe you will have to move anything with the straight bars, but you will not be able to have a CAI or maybe even some SRIs. The straight bars usually don't allow for it.
Old Apr 24, 2003
Master
If you look under your hood, the steering fluid container is sitting right up next to the air box, which is in the way. Is type-R front strut bar sitting higher than that?
Old Apr 24, 2003
Vinh's Avatar
you should be okay....the ebay Type R Front Upper Strut Bar
will fit fine with injen sri or any intake that doesn't bend up.
for some odd reason....Slikor (2k1 EX EBP) has a huge clutch resevoir
but if yours is normal size it will fit fine
Old Apr 25, 2003
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
I just bought the Type-R strut bar from Chinatown like last week. And I don't think its the steering fluid, its the clutch reservoir (or at least for the manual). It fits perfectly.
Heres what you do. Look and you see the bracket thats holding the clutch reservoir. Look in there and find the bolt thats holding in the bracket to the chassis of the car. You'll see two, one on top of the other. What I did is, unscrew the top one which holds the bracket in. Then I unscrewed the lower one and attatched the bracket to the lower one (hence lowereing the clutch reservoir so the strut bar wont hit it). Screw it back into the chassis and voila!!!
By the way, that Type-R strut bar works friggin good!!! I didn't even expect anything from it. I do turns and corners faster and much more easily now, and it seems like I have less understeer. Its no name brand, but it does the job.
Old Apr 25, 2003
Master
So i would still need to relocate the clutch reservoir?
Old Apr 25, 2003
robbclark1's Avatar
yeah probably. I personally did NOT have to relocate my clutch reservoir for my neuspeed bar. I just wiggled it until it fit with the bar. It really isn't a big deal tho. You should be able to do it no problems.
Old Jun 13, 2003
orion_squall's Avatar
but those type-R strut car looks really bad...they are so thin!
are you sure they actaully do something at all???
Old Jun 14, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
well there are 2 reservoirs the clutch reservoir, if u have a 5spd, and the brake master cylinder, basically i unbolted the clutch reservoir and bolted it to a lower spot without any extra parts or modifications
but i belive the type r bars u need to drill holes in the chassis
juror
Suspension DIY
Jul 30, 2019 03:28 AM
JohnnyBxo
Nov 12, 2015 03:04 PM
Dani1993
Jul 24, 2015 09:02 AM
fordover
Jul 11, 2015 09:10 PM
stvpagn
Jul 9, 2015 09:59 PM
