stock fuel+ turbo
Old Apr 20, 2003
old beater's Avatar
old beater is an unknown quantity at this point
stock fuel+ turbo
ok, i have looked around and not really seen an answer. what is max boost on stock fuel? i saw 5psi in another thread. Also the turbo i have has an internal wastegate set at 7 psi. so i need at least that, could i just put another injector in or get 6th gen Si injectors or new, bigger ones? any suggestions would be great, thanks.
nate
Old Apr 22, 2003
Meatman's Avatar
Meatman is an unknown quantity at this point
I hooked up my Injector dutie cycle meter and went all the way to redline in 4th. It was around 80 percent. So I don't know how much more you can pull out of the stock ones. I wouldn't think you'd want to stress them past 90% because they wont last as long. Am I thinking correctly???
Old Apr 23, 2003
Grey's Avatar
DIY King
Redline gave you 80% duty cycle? That's stock? Yes, you don't want to go above 90% duty cycle. At least not for extended periods of time.
Old Apr 25, 2003
Meatman's Avatar
Well I have a light for every 10 percent, and the 80 percnt light was lit up. I remember reading somewhere that either 80 or 85 percent is the standard for cars so that sounds about right.
Old May 4, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
I heard that if you get an RSX fuel pump and injectors, you can run 5psi MAX. But you run rich all the time, which bogs down your engine when you arent in boost.
Old May 4, 2003
RoadRunner's Avatar
man i'm lost
Misfit2613
Jul 30, 2015 09:49 AM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
NoobyKid
Jul 13, 2015 07:53 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
