intercooler piping
Old Apr 18, 2003
prototype's Avatar
x-factor
intercooler piping
so im looking to peice together a turbo kit, i found a 16g turbo in my garage from my mitsubishi days and now im looking for an intercooler....i think im gonna go with a spearco, but the piping, doesn it have to mandrel bent or is pressbent ok? also....im still not knowing what to do about the returnless system....can i keep the returnless system and get bigger injectors? if so....... if n 1 has part #'s id appreciate it
thanx
Old Apr 19, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
You can use press bent, but mandrel bent is going to be best. I'm pretty sure if your turbo puts out x amount of air and there is a restriction in the piping, it would be more prone to surging (kinda like backpressure on an exhaust system). As for the returnless system, you can most likely use bigger injectors and a piggyback fuel computer like GReddy e-manage, or get a standalone ECU like AEM EMS. You could also keep your stock injectors and add an extra injector controlled by a fuel controller. As of right now, I think there is only one person who is working on using just larger injectors and the E-manage (JohnyBlaze?)
Old Apr 20, 2003
prototype's Avatar
x-factor
if i get bigger injectors can i just use my v-afc to control the fuel?
Old Apr 20, 2003
iamboo's Avatar
Retired - SoCal FI Mod
yea the vafc would work...but bigger injectors are useless unless you have some other secondary fuel pump or fuel system to pump more fuel into those injectors... if it's just like one injector then i guess it's okay but for higher boost, you need more fuel to prevent going lean...
Old Apr 20, 2003
Boosted2k2's Avatar
HKS Universal In-tank fuel pump? Wonder if it will work. Link
Old Apr 20, 2003
lucky13matt's Avatar
lucky13matt is an unknown quantity at this point
walbro 255 fuel pump will work just fine
Old Apr 21, 2003
prototype's Avatar
x-factor
when i order the walbro do i have to get 1 for our car or are they universal?
Old Apr 23, 2003
Boosted2k2's Avatar
I think that the 255 is universal.
Old Apr 23, 2003
they do make an universal one
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Cam Diaz
Sep 29, 2015 07:17 PM
michael0219
Sep 1, 2015 10:25 PM
PierrePierre
Aug 12, 2015 02:42 PM
Causemo
Jul 5, 2015 06:42 AM
