What is a crazy boost level
Old Apr 17, 2003
trucka5's Avatar
trucka5 is an unknown quantity at this point
Question What is a crazy boost level
What is the highest boost level you would put on your car that wouldn't blow the engine
Old Apr 17, 2003
derty's Avatar
derty is an unknown quantity at this point
plan to keep mine at 6-8 because mine is a daily driver.Turbodiscounters 4 weeks from now!!!!!!!
Old Apr 18, 2003
cdmx's Avatar
since your talking about a crazy amount...would there be stronger internals?
Old Apr 18, 2003
cdmx's Avatar
and someone explain why a lower compression is better for a turbo...like the pistons from turbodiscounters 8:5:1...
would it still be ok to boost a high compression NA car?
Old Apr 18, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Read this: Link
It answers all your questions and more. It's a very good FYI. On Hondas none the less.
Old Apr 18, 2003
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
i would at least keep it below 8.anymore than that your taking a risk on a stock motor.
Old Apr 18, 2003
Spider883's Avatar
9K Redline Owns U
daily i will only keep mine at 5-6
Old Apr 18, 2003
gotti's Avatar
50!!!
Old Apr 18, 2003
Jodster's Avatar
Post Whore General
I plan on setting mine at 10 psi on my EP.
Old Apr 19, 2003
RoadRunner's Avatar
anything 9 and up your gonna have to totally redo your fuel system, because or civ's dont have a return fuel line. which means more money your gonna have to fork out. like the more boost your gonna want, the more money your gonna have to dish out for the car to be able those high levels of boost
Old Apr 20, 2003
gotti's Avatar
I SAID 50!@@#
Old Apr 23, 2003
Grey's Avatar
DIY King
Originally posted by Gotti
I SAID 50!@@#
We heard you! That's not insane for diesel engines.
I say... 30psi. Basically the maximum that one of those upgraded Eagle blocks can withstand.
If you're talking about a stock D17, then 10psi is insane. No amount of intercooling will save you from a blown head gasket.
Old May 20, 2003
Black99Vtec's Avatar
first member with a d16 swap
Black99Vtec should not be trustedBlack99Vtec should not be trustedBlack99Vtec should not be trusted
insane is 30lbs on an t61 garret turbo on a 4cylinder. putting out a lill over 600 wheel hp
Old May 21, 2003
SuperNegro's Avatar
SuperNegro is an unknown quantity at this point
8.5:1 is extremely low unless you plan on boosting 14+ psi on a regular basis for anything less you would be better off running 9.5-9.8:1 compression.
Old May 21, 2003
Jodster's Avatar
Post Whore General
thats what I have stock on my SI. 9.8:1 compression ratio.
Old Aug 4, 2003
Chrissy's Avatar
Chrissy is an unknown quantity at this point
ohhh yieaah, thats mooorrew likje pusshshing 100000000 hp ssisince itiss a fooofore silinder.
Old Aug 4, 2003
Boosted2k2's Avatar
lease: good point?
Old Aug 4, 2003
JoeyOKC's Avatar
http://ackakaka.ytmnd.com
JoeyOKC is on a distinguished road
I know of a Diesel in oklahoma that's pushing over 600hp 1100ft/lbs and is running about 80psi on a custom twin turbo setup.
Old Aug 6, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
i was doing 12psi fine for one day.
Old Aug 6, 2003
Stone's Avatar
Stone is an unknown quantity at this point
on my wish list is a sleeved block from Polk Performance here in Arkansas. Its guaranteed to handle 60 psi all day long. They get the block sleeved by the same people that do work for NASA.
$900 is the price to pay.
AWESOME!
Of course, you would have to have an all-forged assembly to handle all that, but we can dream, right?
$900! gawd.
Old Aug 7, 2003
Chrissy's Avatar
AWESOME!
$900! gawd.
geez, you might be the first 300 hp d17 on the block, a sure stock n/a supra killer
Old Aug 7, 2003
andyman97's Avatar
Turbo Guru
You'd dust modded supras with that kind of power with a good launch and good tires. Of course you'd want to get stronger axles. I plan to sleeve my block this winter and pick up forged internals with a new intake manifold and some serious headwork. I know I'll probably spend a good 3 grand on it but it'll be well worth it. 450 whp
Old Aug 7, 2003
Stone's Avatar
Yeah I'm going to get the internals first...slowly and one piece at a time.
Then the seeves and headwork.
I can do all the porting and polishing myself, but I will have to pay for the bigger valves and 5 angle valve job they do there.
After that its clutch and axles.
I know after that 450 hp isnt going to be too far away
Just a turbo install away that is....
I'm probably looking at at least $3500 before turbo.
But the look on my buds face when I dust his '79 Trans Am with a 455 Big Block!
Ah turbos........
Old Aug 7, 2003
iamboo's Avatar
Retired - SoCal FI Mod
Ah turbos........
starting to kinda sound like black99vtec....
Old Aug 7, 2003
andyman97's Avatar
Turbo Guru
I plan on doing the same setup to my block this winter.....and I WILL provide proof once it's built.
Old Aug 8, 2003
wenlyone's Avatar
wenlyone is an unknown quantity at this point
Hey andy. You went with the SF kit right? What is your dyno number?
Old Aug 8, 2003
andyman97's Avatar
Turbo Guru
Haven't installed it yet. I'm running at the track for time Saturday and I'll post the slip when I can.
Old Aug 8, 2003
wenlyone's Avatar
Thanks. If you need any help just message me. I want to see good numbers. Gotta pursuede my friend to boost his civic.
Old Aug 8, 2003
andyman97's Avatar
Turbo Guru
Not to be conceited but I have nothing but the best helping me out with the install. My goal is low 13 (keep in mind I'm at 6,000 ft.)
Old Aug 8, 2003
wenlyone's Avatar
Nah, you probably does have good help. Just in case you guys all get stuck and can't get good results, my offer still stands. Eventhough I know very little about the new honda heart, I am sure 13's will be a easy task. From what reading all your posts, I am sure you won't be satisfied with 13. I will be sure to see you in the 12's. LoL
Here is our project B18C1.
If you help me find enough info to push my friend to turbo his ex, I will be happy to answer all the questions you have about turbos.
Wen
