Turbo kit is now available at TurboDiscounters.com
I called them up today and he said the extreme kit is gonna run anywhere from 2600.00 to 2800.00 and the kit is designed to run 16 psi, it comes with everything and its a complete bolt on. Keep AC and PS and the fuel system is taken care of by bigger injectors. I have already preordered the kit and its ETA is in 4 weeks from today. I can install this kit and still keep factory warranty with the sponsership i have with my dealership. Ill keep you updated. Im wondering if they can hook my up with a larger turbo tho.
Kit contains *
1 Garett Turbo (size is depending on kit ordered)
1 Down Pipe
1 High Nickel Composite Cast Exhaust Manifold
1 Fuel Pressure Regulator
1 Injection Control Unit
1 Injector interface block with injectors
1 Blow off valve
1 High flow intercooler with all mounting hardware, pressure tubes,
rubber hose connections and clamps
1 Map unit (Black Box)
1 Oil Return Line and Fitting
1 Air Filter with piping
i cant wait! said to produce close to 75hp at the wheels he said
There is also a smaller kit called the superior kit and its not as much money. and doesnt consist of the same components
Kit contains *
1 Down Pipe
1 Blow off valve
Post Whore General
Originally posted by JamesL
16 psi????
that seems a bit high...
16 psi????
Re: Turbo Discounters Update
btw, thanks for the update, keep us posted for sure!!!
Great info. I'd like to know if it works with the LX models since that's what I got. I wouldn't think V-tec would make a difference for the application.
Also is there a link to the company or how/where to purchase the kit?
the only thing that worries me, is are those brand name parts, or just cheap pos's. because i'd feel safer if they had brand name parts in their turbo packages. if i'm gonna turbo my car i would do it right the first time ......... you get what you pay for
Retired - SoCal FI Mod
i don't think bigger injectors would do it for me... what if later down the line i do some internal work and decided to boost more?? i would still need more fuel and i think new injectors would come short of what i need.... sf turbo kit comes with a secondary fuel pump and management system... it's too early to say which kit i want because there are only numbers out for the sf kit... once the numbers from the turbo discounters kit comes out, i'll decide from there....
Originally posted by derty
this turbo kit works for all models of the civic -=]
Originally posted by iamboo
are you sure?? cause there needs to be different downpipe sizes for the kits seeing how the cats on the LX/DX are different from the cat placement on the EX...
Turbo kit is now abailable at TurboDiscounters.com
You asked to be notified when we started selling D17A turbos, they are now
available here:
http://www.TurboDiscounters.com/html/Turbo-Honda.aspx
The Extreme kit is $3,120, the Superior kit is $2,100. Both kits come with
the new Garrett T25 Dual Ball Bearing turbo!
Check out our site for more info.
TurboDiscounters.com +>
(800) 861-0691 - http://TurboDiscounters.com
available here:
TURBO AVAILABLE FOR D17 !!!!!!
Finally!!!!! T.D. came out with Turbo for our babies !!! a beautifull T25BB...
This is the happiest day in my life..
Can anybody borrow me $3,200 ???
Originally posted by emmc
they said it was gonna be under 2800$
Originally posted by xmeeksx
will this pass emission? because they are strict here in VA
IM gonna be all over this, i did have one question the pipijng for this whats it gonna be? i saw on your site and it actiually looked like it was flexible piping. Is this true?
The pipes are metal, with rubber seals holding the pieces together. It gives a nice look and can easily handle the pressure.
I might be all over this dunno yet still wanna see some numbers between the 2 kits out for it right now and also the other turbo kit shop is located so close to me =] so dunno yet.
