where in fuse box to put remote turn on wire
Old Apr 17, 2003
cdmx's Avatar
(the amplifier turn on wire)
Yea right now i have it straight to the battery with a switch to turn the amp on and off.
Im always forgetting to turn the damn amp off and i have to jump the car alot...
The sub has been out of my car for sometime now so i haven't been using the amp but now i want to wire it up right.
I was told you could wire it to the fuse box to someplace that was feeding a 12v signal when the car is on...Anyone know exactly where? Im too lazy to check with a voltometer
Old Apr 17, 2003
LudlamTheory's Avatar
i boogie for the raindrops
if you have the stock HU, wire it to the yellow wire on the cigarette lighter. If you have an aftermarket radio, hook it up to the remote wire on the aftermarket radio.
Old Apr 17, 2003
cdmx's Avatar
ive done that and the fuse for the cig lighter blows!!
Old Apr 17, 2003
what are you running off that? im running 2 amps, a crossover, a switch, and a real cigarette lighter
Old Apr 17, 2003
DizWikedCivic's Avatar
tap into the factory harness, look for the ignition wire,
Old Apr 17, 2003
cdmx's Avatar
thank you DizWikedCivic
Old Apr 17, 2003
WhiteRabbit's Avatar
or you could use a relay.
Old Apr 18, 2003
Falcon's Avatar
Falcon is an unknown quantity at this point
mine is hooked to the ignition wire... actually to the ignition fuse in the box just above your right knee
roverben
Jan 21, 2019 05:16 PM
Fastfebur
Apr 22, 2015 01:37 PM
smmahan
Apr 15, 2015 08:17 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
cazminn
Nov 9, 2001 11:18 AM
