springs/tire size combo w/o problems?
Old Mar 27, 2003
bench's Avatar
bench is an unknown quantity at this point
Need suggestion on which spring(type, model, inch drop) and 17" tire size combo your are running without having any issues about rubbing in the rear and front when you have passangers in the rear. you rim offest would be help also.....post pics if any...
Old Mar 27, 2003
666's Avatar
666
666 is an unknown quantity at this point
I have a set of H&R Sport springs with 18X7 rims (+42 offset) and 215/35-18 tires. The drop was about 1-1/2"-1-5/8" after the springs settled and I do not have any rubbing. For 17" wheels I would probably use a 215/45-17 tire and there should not be any problem either.
Here is a photo:
Old Mar 27, 2003
bench's Avatar
thanks...car look great....are you on oem shocks....have chamber kit?
Old Mar 27, 2003
666's Avatar
666
Thank you. I have Koni yellows and a Eibach camber kit in the rear only. Rides very smooth, I think it's perfect.
Old Mar 28, 2003
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Here is a photo:
For that height it looks like a 215-45-17 wouldn't rub. It's common that size will rub (with the tire being a 215 even if it's on a 16 inch rim) so as long as it's not low enough. Wish I had a better view of your car from the side.
Old Apr 11, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
I have 215/40/17 lowered 1.5 and it doesn't rub at all. The wider tire gives my car better handling.
