Sponsored by:
Sponsored by: CARiD
exhaust and rattling noise
Old Mar 23, 2003
xmeeksx's Avatar
xmeeksx is an unknown quantity at this point
ok, i know about the rattling or vibrating noise that comes from the midsection pipe when it gets wet. but which aftermarket exhaust suffers from this. i read somewhere that it was all of them? is this true because i guess i will just go with an axle back to avoid this issue. i have enough vibrations in my car. can u guys post the exhaust u have if you are having this rattling/vibrating sound from rainy weather?
Old Mar 24, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
many members (myself included) have had this problem for some time now. there were a few threads posted in vehicle problems/issues. for me, i think a part of the pipe is rubbing against the body of my car (or that's what it seems like to me). i recently put a cloth between those 2 parts today and notice less of the knocking sound when i go on bumpy roads. to answer your question, yes, getting an axle-back exhaust can prevent this from happening. i'm assuming that my problem is due to the routing of my exhaust piping
Old Mar 24, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
sweet i finally know what that noise is. i just started hearing that about 2 days after getting my exaust put on
Old Mar 24, 2003
sc1golfr's Avatar
sc1golfr is an unknown quantity at this point
i get that noise with my tanabe rspec
Old Mar 24, 2003
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
I also get that noise with my greddy exhaust. I've gone to honda and many other places. No one can figure out the problem. They also tell me that the exhaust is hitting somewhere but can do nothiing about it. Anyone found a solution with this.
Old Mar 24, 2003
NeonImpact's Avatar
Forum Sponsor
lol i pulled in a gravel driveway today and i heard that, slammed on the brakes, and was like WTF MY BOLTS ARE LOOSE!!
Busted out the socket wrench set and found out everything was tight
Came here, saw this post, and hit my self in the forehead..
I have the Greddy EVO also..
It dont bother me anymore now..
Old Mar 25, 2003
Bartkat's Avatar
One good reason not to put "custom" exhaust.
Old Mar 25, 2003
THERING's Avatar
THERING is an unknown quantity at this point
I get dat with my G-Spec exhaust too!
Old Mar 27, 2003
ripper's Avatar
ripper is an unknown quantity at this point
I have the HKS axle back and get the same problem. The exhaust shakes and taps against the frame right by the rear wheels when the car is cold. When the car is hot this doesn't happen, and all bolts are tightened.
Old Mar 27, 2003
AllMotorSi's Avatar
I was thinking of going to the shop to see if they can weld an extra hanger so it doen't hit anymore. I'm gonna write a letter to greddy and complain about this one.
Old Apr 8, 2003
xmeeksx's Avatar
anyone tried wrapping up the pipes with heat wrap?
Old Apr 8, 2003
HomerSimpson's Avatar
I get the sound on my magnaflow cat-back when it is cold water, never ona warm day/
Old Apr 9, 2003
killakoala's Avatar
killakoala is an unknown quantity at this point
the sound is from your pipe tapping against the sway bar. You can slightly bend the sway bar away from your piping, but itll eventually go back to its normal place. The best thing to do, is wrap your pipe or the sway bar with some heat resistant padding. The sounds not necessarily a bad thing, its just that a lot of the suspension pieces on our cars are located in crappy places.
Old Apr 9, 2003
Bartkat's Avatar
It's not in a crappy place for the stok exhaust.
Old Apr 9, 2003
chirpin2k2civic's Avatar
chirpin2k2civic is an unknown quantity at this point
http://www.7thgencivic.com/forums/sh...threadid=86281 that why u guys get this one and convert it into a axle back =)
Old Apr 9, 2003
Bartkat's Avatar
What's that trumpet shaped thingy?
Old Apr 9, 2003
2k1sscivic's Avatar
2k1sscivic is an unknown quantity at this point
Bartkat: that seems to be the silencer which is removeable.
Old Apr 9, 2003
killakoala's Avatar
the stock piping is a lot smaller than most aftermarket or custom exhaust piping. Mines a 2 1/4 custom pipe, and I tap occasionally.
Old Apr 9, 2003
7thgencivic9's Avatar
7thgencivic9 is an unknown quantity at this point
ok the best idea would be to get a rear section exhaust to prevent the rattling?
Old Apr 9, 2003
Bartkat's Avatar
I think it would depend on how the rear section is made. It's gonna be right there where it can bump the suspension and if it's too big or angled wrong it can still hit.
Old Apr 9, 2003
killah99si's Avatar
killah99si is an unknown quantity at this point
apexi n1 does it too
Old Apr 9, 2003
Bartkat's Avatar
The HKS is a rear section only, isn't it?
Old Apr 9, 2003
PunkingCivic's Avatar
I need TP for my bunghole
I agree with xmeeksx
Try to use some heat / header wrap on the exhaust.
It couldn't hurt it.
exhaust wrap kits @ carparts.com
15EXCoupe
Jul 30, 2015 12:59 PM
Yazan93
Jul 14, 2015 08:56 PM
hayden55
Jul 8, 2015 11:38 PM
fvckbg
Jul 7, 2015 07:08 PM
