bolt pattern,offset,drop
Old Mar 21, 2003
NBPD17A2's Avatar
NBPD17A2 is an unknown quantity at this point
I understand that our cars use a 4x100 bolt pattern, but the wheels I am looking at have 2 choices of 2 bolt patterns. 4x100/4x108 or 4x100/4x114.3. Which patterns are better?Which one has more material between the holes?
As far as offset, Im reading that a +40mm to +45mm is ideal for a 17" x 7" wheel? Would it be better to go with with the 40 or the 45 or does it not matter?
Lastly, I might drop my car in the future. I will be using 215/45-17 tires. I know this question has been asked many times. Will they rub with the drop? Ive been reading on here and seems that some people do and some people dont. The ones that did only had the problem once they lowered the car. What would cause this not to work? Wrong offset? Wider wheel(7.5")?
Thanks.
Steve
Old Mar 21, 2003
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
i would go with 4x100 & 4x114.3. The reason is that 4x100 fits civics and integras, and 4x114.3 fits accords and other import big 4 lug cars. the 4x108 is for ford. designed for the focus. so its up to you. i currently have th 215/45/17 tires. my offset is +40MM and i have no rubbing problems and my car is dropped with H&R springs. My car never has any rubbing problems even with a full load.
Old Mar 21, 2003
NBPD17A2's Avatar
Thanks. That is what I was looking for.
Old Mar 22, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
The rubbing could have to do with several things... it also depends where it's rubbing. I know right now, if I drop my car too far, I'm going to put the rear tires right through the fenders. I've got Superleggeras which have a 37 offset, putting the centerline in almost the wheel in exactly the same spot as the stock wheels. So they just hang an extra 1/2" on each side of where the stock wheels would be (7" vs. 6"). Problem being that the 1/2" on the outside is under the rear fender lip and if lowered too far would cause a rub there. If there's too much offset, you could end up rubbing the spring perch or maybe the fender liner when you turn the wheel. There's lots of causes that could create a rub in different locations.
I would go with the 40 offset, 100/114.3 combo... it should cover almost all 4 lug FWD cars.
Old Apr 11, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
I go with the 4x100/4x114.3 lug pattern, the +40 offset, and with that tire size I wouldn't drop it any more than 1.75.
Old Apr 11, 2003
cvc2k2's Avatar
lower the offset.. the more it sticks out.. higher the number.. the more it tucks. if you would go with a 17x7.5 or a 18x7.5, 7.5inch width, i recommend +42MM. if you would use a +40MM on a 7.5" rim, it might rubb the outter fender and the fender has to be rolled. if you use a +45MM on a 7.5inch width rim, it will rubb in the inner wheel well if your car is really low or when you hit bumps forcing the wheel to go into the wheel well.
honda.lioness
Aug 21, 2015 02:36 PM
GritzNGravy
Aug 19, 2015 03:03 AM
frisbeeguy2
Jul 30, 2015 03:00 PM
Misfit2613
Jul 30, 2015 09:49 AM
mrohitredd
Jul 21, 2015 09:26 AM
