ive searched but no one knows, i know its the o2 sensor wireair/fuel
Old Feb 27, 2003
jamesbbh's Avatar
jamesbbh is an unknown quantity at this point
what wire do i hook it up to? i know its the o2 sensor wire but which one is it? theres 2 white, 1 black and a grey wire
ive searched but no one has said which one it is
thanks a lot
James
Old Feb 27, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
u prolly wanna take it to the pro, i mean u dont have to let them put it on...maybe ask them....
Old Feb 27, 2003
RedLine6876's Avatar
RedLine6876 is an unknown quantity at this point
Wire it lower; to the white with black stripe on it just after the connector off the header
Old Feb 27, 2003
AFlyer's Avatar
AFlyer is an unknown quantity at this point
i think it depends on whether you have a sedan or coupe. i have a sedan and the sensor is tapped into the black wire, that's the only one that would make the gauge work right. but i've been hearing white with black stripe from people, which isn't even an option for me. so if you have coupe, go with the white with black stripe, if you have sedan, go with black.
Old Feb 27, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
This picture should help you you.....
as you can clearly see its the black wire on the 1st and 2nd o2 sensor. I believe the a/f gauge should be hooked the the first o2 sensor. Later...
Old Feb 27, 2003
jamesbbh's Avatar
i thought that it measures the voltage return from the sesnsor though?
Old Feb 27, 2003
PatrickB's Avatar
PatrickB is an unknown quantity at this point
white with black wire I will try to get a picture of it this weekend. btw what do you need the gauge for? anything fun on the car?
Old Feb 27, 2003
jamesbbh's Avatar
NOS 75 SHOT
NOS PURGE
INTAKE
HEADER
EXHAUST
NEW PLUGS
Old Feb 27, 2003
PatrickB's Avatar
Quote
[hr]Originally posted by: jamesbbh
NOS 75 SHOT
NOS PURGE
INTAKE
HEADER
EXHAUST
NEW PLUGS[hr]
cool the civic that i will be taking pictures of the af o2 hook up has n2o. 50 shot though. good luck.. pretty crazy putting a 75 shot on without a egt or atleast a a/f.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Rlss
24
Feb 26, 2016 09:42 PM
juror
May 26, 2015 06:35 PM
dezod
Engine Swaps
42
May 25, 2006 11:37 PM
mal
Jun 23, 2005 09:19 AM
