Help real fast! Dashlight fuse blew!
Old Feb 25, 2003
Hwoody77's Avatar
Hwoody77 can only hope to improve
What's up guys, does anyone know where the dashlight fuse is? It is the same fuse used by the rear license plate lights...please help...thanks.
Old Feb 26, 2003
greg2k1's Avatar
greg2k1 is an unknown quantity at this point
I'm sure you've checked the diagram...I know when my dash was apart with no lights my emergency lights didn't work wither maybe that willl help
Old Feb 26, 2003
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
there should be a diagram on the door that covers your interior fuse box. look at it, it tells you which fuse is what. If worst comes to worst, pull em out 1 at a time till you find the blown fuse. itll be easy to spot because the little metal connector inside the plastic will look like it exploded.
Old Feb 26, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
should be right next to the cig lighter fuse, and that fuse located under ur steering wheel. just clip the pan off and its on ur top right corner
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Robertsv
Aug 26, 2015 11:02 PM
Ma213802
May 18, 2015 07:01 AM
smmahan
Apr 15, 2015 08:17 PM
pimpedcivic
40
Jul 23, 2002 11:41 PM
