Radio Effing Up When It Rains or I Wash???
alright, i got a question, my radio keeps messing up when it rains or i wash it... when i take it to honda dealer, they say they cannot locate the problem, and they can't even get it to do it. used to, before i installed my system, when it'd happen, i'd get nothing, but now that i have a sub, i get the lower frequencies. it did it with the factory hu, and now with the after market one. i am not shorting out any where i can find, but, a while back, one of my fogs came unplugged (before i had my kit), and it was scrubbing the ground for a while (the plug that you plug into the actual light). i found it, and replugged it, but it is not the whole assembly as it was before this, it rubbed the snap thing off of it, so now it's just kinda on there and not held into place. anyway, i pinned them up while i had the octane on ther, so they wouldn't scrub any more, and now that i have the factory front back on, i plugged the fogs back up. anyway, could the fog light plug be affecting the radio, thats the only place i can see where any wires may be getting moisture on them. if this is the case anyone know where i can get the harness for one?
hmm.. i thought i explained it in my original post, but maybe this is clearer...
i am driving and the radio is fine, until it rains or i wash the car.... then almost everytime, it will play only the lower frequencies, i know that it is playing them cause my sub is hitting, but anything from around 100hz and up does not play, i used to not get anything before i got my sub, but now i get the bottom frequencies...
I would wager that water is leaking into the doors and shorting your speakers or speaker wires....open the doors up after it rains, or you wash the car, and check for water on the wires, or corrosion. The solution to that problem would be a set of Speaker Baffles
You might also want to snip the corroded part of the wires, if they are at all. Are you running OEM or aftermarket speakers?
no, that's not it, i already checked, i don not have any OEM ice in my car... not ever wires, the wires are 12 ga and there are no naked spots, and its not just the front speakers, its all of them,the front 6&1/2" s, tweeters, and rear 6X9's... all of them have been replaced, wires included, and the fronts have baffles, so that's not the problem, i can't figure it out...
i know this may sound stupid but in the back where the piller is on the right hand side, that is where the antenna wire plugs into your car. i think it might have to do with temperature because your car is cold after you wash it. i would check the antenna wire connection to the antenna in the rear and to the back of your deck. Since you said you rewired your system you might like have accidently cut into the wiresomewhere and check the ground on your amp to see if thats not causing the problem. also did u run your power and your rca wires down seperate sides of the car? that might also be a problem. i would definately check out that antenna wire.
The antenna wont have a thing to do with it....all that would affect is the radio reception....as far as the problem goes, check with a car audio shop....they might be more suited to help you. Are you speakers hooked up to an amp or off the HU? the connection for the amp under the hood might be getting wet.....I donno man. Thats a really weird problem.
the car audio shop i do some work for has looked at it and they can't figure it out either, that is why i asked if the fog lights could be affecting it, and it isn't just when i have it on the am/fm tuner, it is also when i play cd's, mp3's or whatever... or with the oem HU, the cd's and tuner... and it never did it before the fog light wire got messed up, that is why i am thinking that that is where the problem is, or at least part of the problem, i still can't figure out why that would be, but that is about when it started....
that's what i am thinking, but where can i find just the connectors? they are OEM fogs, and honda will only sell me the entire set, lamps and all, i just need the plugs, if anyone isn't using their oem fogs anymore, i would buy the connectors off of them...
jdawgzcivic
17
Feb 1, 2020 04:16 PM
ricer_em2
May 11, 2016 08:09 PM
Raiool
Oct 1, 2015 10:42 AM
Mc7602
Sep 17, 2015 02:01 PM
