Does tire size affect gear ratio???
Old Feb 7, 2003
inos's Avatar
inos is an unknown quantity at this point
I have the stock 185/65/15's on my car... just orderd some 215/40/17's
I used the tire calc and it states that the speedometer reading on the new tire size is 2.89% fast...
would that affect my gearing ratio in a negative or positive way???
One thing, I know if your rotational mass is larger than stock, you go slower, because there's more mass to turn... what if it's smaller?? would the car, in essence, go faster???
with that said, 185/30/15's * i know there isn't a tire with that size but for arguments sake* would make me go faster because of less rotational mass??
thanks for any help guys!!!!!!
Old Feb 7, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Acceleration wise, smaller tires will give you shorter final gearing (they don't effect the gears inside the tranny) and faster acceleration.
Top end... Larger than stock diameters will give you higher top speeds, but slower acceleration.
In theory, within a rim size there is such a small difference in inertia (since the mass is basically the same distance from the hub) that it can be neglected. Now if you're comparing 14's to 18's, yes... you will probably notice a difference in starts. Once the wheels are rolling at a good clip... it won't make too much difference.
cruisers10
May 12, 2015 10:46 PM
Jc20unc
Dec 10, 2001 08:32 AM
NightKids2
Dec 8, 2001 05:50 AM
supercivic01
South
Nov 30, 2001 11:27 AM
