Shocks from another car?
Old Feb 5, 2003
cdmx's Avatar
Will shocks from another car work with our 7thgens? rsx, si? with slight modification or none?
Old Feb 5, 2003
solar's Avatar
solar is an unknown quantity at this point
You could buy after market shocks that are just as good or better than a RSX or Si's that would bolt right up in a Civic. As far as your question goes though, I don't know if RSX or Si shocks would fit.
Old Feb 5, 2003
Vesper's Avatar
Vesper is an unknown quantity at this point
dont know about the back but i really doubt the from will. we have the mac phurson suspention.
and i can spell.
Old Feb 5, 2003
Vesper's Avatar
holy ****.[IMG]i/expressions/face-icon-small-mad.gif[/IMG] front and cant im a mess tonite
Old Feb 5, 2003
dragoon's Avatar
RSX and SI should fit with minimal modifications, they have macpherson up front also.
Old Feb 5, 2003
cdmx's Avatar
Has anyone done this? I just want something other than my stock shocks and something cheaper than full coilovers or konis...
Old Feb 6, 2003
solar's Avatar
Quote
[hr]Originally posted by: cdmx
Has anyone done this? I just want something other than my stock shocks and something cheaper than full coilovers or konis...[hr]
Unless you buy used shocks off a RSX or Si,(which I wouldn't do), you won't be saving any money buying new shocks from a Honda or Acura dealer. Check around for performance aftermarket shocks and struts, you don't nessasaraly need coil overs or Koni's, but you will need to buy new front struts and those will cost a bit no matter who makes them.
Old Feb 6, 2003
CivicHX01's Avatar
Quote
[hr]Originally posted by: solar
Quote
Unless you buy used shocks off a RSX or Si,(which I wouldn't do), you won't be saving any money buying new shocks from a Honda or Acura dealer. Check around for performance aftermarket shocks and struts, you don't nessasaraly need coil overs or Koni's, but you will need to buy new front struts and those will cost a bit no matter who makes them.[hr]
as a matter of fact, OEM shocks/struts run about $200 each... your better off getting aftermarket ones (koni's are about $130-$140 each brand new)... so you'd actually be saving money when buying aftermarket ones..
Old Feb 6, 2003
Grey's Avatar
DIY King
It works for sure. You can use RSX or 2002 Si shocks. It's the same McPhearson front suspension. ASWzero has the Tein Flex coilovers for his car for example. He had to cut some of the hood underskeleton out, but you wouldn't have to do this if you had a hood like the Fiber Images.
Old Feb 6, 2003
VNlilMAN's Avatar
The Standard One
oh and just to let you know there are just as many shocks for them as there are for us . the koni's just came out a couple months ago for the RSX's and those are just inserts too..
but ya you'll have more options in the true coilover department tho.
Old Feb 6, 2003
cdmx's Avatar
Quote
[hr]Originally posted by: Grey
It works for sure. You can use RSX or 2002 Si shocks. It's the same McPhearson front suspension. ASWzero has the Tein Flex coilovers for his car for example. He had to cut some of the hood underskeleton out, but you wouldn't have to do this if you had a hood like the Fiber Images.[hr]
Which would u say have the better shocks, if i can get either slightly used....for cheap are they better than the stock vic's? And did someone also say i only need front ones?
What im really trying to acomplish here is after getting lowering springs I dont want to have to go throught the hastle of blown shocks prematurely...And i dont want to spend alot of money (should i wait for the tokicos? when they comin out?)
Old Feb 6, 2003
Grey's Avatar
DIY King
I have no clue if they're "better"? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
They're probably more stiff than what we have, so they're tuned for the RSX's springs. That's OEM though. I don't know about the aftermarkte for the RSX that much. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 6, 2003
VNlilMAN's Avatar
The Standard One
i'm sure they're better but question is how much better... how cheap can you get them? if they're $300 i rather spend the extra $250 and get konis...
someone mentioned that the SI struts were 1" shorter then the civics. this would put less stress on the shock since its not as compressed all the time.. i personally wouldnt do it tho, whether or not is better then ours its still for a stock car..
Old Feb 7, 2003
cdmx's Avatar
ok thanks....saving for the konis..now i dont want to lower till i get the konis
-By the way will goldlines work with konis?
Rardon6thgenCiv
Apr 15, 2015 07:37 PM
Thees1
Apr 14, 2015 08:23 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Elusiv1
Nov 8, 2001 09:55 PM
