Throttle body Spacer
Old Feb 4, 2003
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
what does ur sound like..i have it...but sounds like idleing up and down...
is ur like that...it's from helix..
HELIX SPACER
Old Feb 4, 2003
Nuts's Avatar
Nuts is an unknown quantity at this point
yeh, i was looking into on of them. how does it perfom. anything good?
Old Feb 4, 2003
Wanger's Avatar
Wanger is an unknown quantity at this point
this looks like one of those scammy "tornado" thingys.
Old Feb 4, 2003
Grey's Avatar
DIY King
It shouldn't "sound" like anything. If your car is idling up and down then there's a problem somewhere. You probably have an air leak. Check that all mating surfaces are sealed properly.
Old Feb 4, 2003
Engineman's Avatar
T.V. is bad for you. Go outside.
Engineman is an unknown quantity at this point
I have the same thought as Nuts. Does it help?
Old Feb 4, 2003
blouisgod's Avatar
Life Begins > 6800rpms
I had one a toyota 4x4 with a 4cyl. they just increase response, stabilize idle, and smooth out acceleration. Grey posted before that if you have an AEM CAI, you wont be able to use one due to clearence issues with the hood.
Old Feb 4, 2003
RiceBuRNeR's Avatar
Turbo Member
hmm, why not just cut a little off the pipe on your CAI?
EDIT: I have a few friends who have them on 4 cyl s10's who say they work great.
Old Feb 4, 2003
BIGLIMPDOG's Avatar
BIGLIMPDOG is an unknown quantity at this point
they work great and you can raise your redline by adding a 1" spacer, every 1" is 1000 rpms. The crappy thing about this is our cars are redline controled so you would need like a hondata unit to take full advantage of the throttle body spacer! If copmuter is programed right your can pull about 12-15 hp and 8-10 flbt, Most of the hp increase comes from the fact that you can now redline at 8 instead of 7! My point is that it takes all the right stuff to get the response they advertise but it is possible!
Old Feb 4, 2003
blouisgod's Avatar
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 4, 2003
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: BIGLIMPDOG
they work great and you can raise your redline by adding a 1" spacer, every 1" is 1000 rpms. The crappy thing about this is our cars are redline controled so you would need like a hondata unit to take full advantage of the throttle body spacer! If copmuter is programed right your can pull about 12-15 hp and 8-10 flbt, Most of the hp increase comes from the fact that you can now redline at 8 instead of 7! My point is that it takes all the right stuff to get the response they advertise but it is possible![hr]
Yeah dude, whatever you say. Dayum, so if I had a chimney comin' out of my hood I could rev to 40,000rpm! Hell yeah bish, uber ricer power! [IMG]i/expressions/laugh2.gif[/IMG]
Old Feb 4, 2003
1028CiViC's Avatar
I'll fix the idleing tomolo, as for mods i had b4..
headers, cat back with hks hiper aem pulleys injen race division
and mine is lx auto....and after i put the spacer my ideling was higher
but the throttle responese is better...like better torque...
should i check the throttle bodie? because when the car starts
it's like gas hitting up and down...i can hear it from my exhaust noise going up and down..
it wasn't like this before, it's right after i install the spacer....
did it happen to any of u guys?
Old Feb 5, 2003
REDVIC's Avatar
One of few in the 13's
REDVIC is an unknown quantity at this point
Just purchase the APC Breather... Everything should go back to normal... [IMG]i/expressions/beer_yum.gif[/IMG]
Old Feb 5, 2003
1028CiViC's Avatar
i've put the hose back, but the ideling is still so high..what shoould i do?
Old Feb 6, 2003
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
Quote
[hr]Originally posted by: Grey
Quote
Yeah dude, whatever you say. Dayum, so if I had a chimney comin' out of my hood I could rev to 40,000rpm! Hell yeah bish, uber ricer power! [IMG]i/expressions/laugh2.gif[/IMG][hr]
[IMG]i/expressions/face-icon-small-nono.gif[/IMG][IMG]i/expressions/face-icon-small-nono.gif[/IMG] If you are serious: Learn some basics about engines before poting, I really hope you were joking, but that was still lame.
Old Feb 6, 2003
Grey's Avatar
DIY King
You talkin' to me or BIGLIMPDOG, 'cause it's me you're quoting. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Anyway, take the throttle body spacer out 1028CiViC and see if the idle is still messed up. If it is then it's not the throttle body spacer that's causing it. It's something else that got messed up while putting in that throttle body spacer. Do that and let us know, otherwise it's kinda pointless for us to tell you how to fix it if it's the mod itself that's causing the problem.
Old Feb 6, 2003
1028CiViC's Avatar
Quote
Anyway, take the throttle body spacer out 1028CiViC and see if the idle is still messed up. If it is then it's not the throttle body spacer that's causing it. It's something else that got messed up while putting in that throttle body spacer. Do that and let us know, otherwise it's kinda pointless for us to tell you how to fix it if it's the mod itself that's causing the problem.[hr]
ok thanks for the advice anyway...i am going to take out the throttle body spacer later on tonite and see if the idleing is still like that...at first i was wonder ing if anyone's was like that....
Old Sep 1, 2005
D17rider's Avatar
D17rider is an unknown quantity at this point
I believe what you would need to do is, that DIY throttle cable adjustment, it should be in the DIY. When you moved the throttle body up 1in i think the acceleration cable is pulling and you need to loosen it so the idle is back to normal which should be below 1K or so. Let me know if this helped, because i still wanna put my spacer in there.
Old Sep 1, 2005
diskreet's Avatar
holy thread revival D17rider!!! this thread is over 2.5 years old!
i bet they got it sorted out by now. but thanks for contributing.
Old Sep 1, 2005
streetglower's Avatar
closed.
SammySC
121
Apr 7, 2017 07:43 PM
carid
Sep 28, 2015 10:13 AM
Bruce2
Sep 27, 2015 08:45 PM
2.0.0.2
Sep 14, 2015 06:38 PM
Bricoleur
Sep 9, 2015 12:30 PM
