Problems with amp...
Old Jan 31, 2003
doubledeuce2k2's Avatar
I got a kenwood 728s the other day, and have been blowing up fuses like crazy. i have connected the ground wire, the remote turn on wire, the speaker wire (i have it bridged correctly), and the RCA's. i have the battery wire connected, but when i go to connect it to the dist block (system if turned off) it sparks and blows the fuses. i have it set to LPF and it is now in stereo (although i tried it in mono and it blew fuses too). the only thing i can think of is the gain ****, but would this be a problem with the system off? any tips people have will be appreciated, it's really ticking me off.
Old Jan 31, 2003
LudlamTheory's Avatar
i boogie for the raindrops
youve got a short somewhere
Old Jan 31, 2003
Ed's Avatar
Ed
Yeah, your have a short. Go check all your wiring again. I'm sure you'll find somewhere that the wire is grounding. better the fuse than your amp [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 1, 2003
argh i am mad, i think i switched the ground and power leads before and fried the amp. that's what i get for using red wire for both. anybody know what i might have fried if this is so? i am a EE major so if it's replacing an amplifier circuit or soldering something i might be up for it.
Old Feb 1, 2003
if youre an EE major then just jump in there with your multimeter
Old Feb 1, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
speaking of amp problem, my amp is outputting a pitch sound to my sub, no blown fuses, and no other sound output, just the pitch sound, a longgggg pitch that wont end unless i turn it off[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 2, 2003
Quote
[hr]speaking of amp problem, my amp is outputting a pitch sound to my sub, no blown fuses, and no other sound output, just the pitch sound, a longgggg pitch that wont end unless i turn it off[hr]
check if your RCA's are touching the chassis at any point. or maybe a break in the RCA somewhere. try moving the wires behind the HU while the system is on too, sometimes you get lucky like that
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
