JET ECU vs AEM Cam Gear
Old Jan 29, 2003
zetaR's Avatar
zetaR is an unknown quantity at this point
Maybe someone can provide a little more insight into this. I noticed someone metioned in another thread concernig the ECU that they called JET, and one of the main things JET does to the ECU is advance the timing. Well, if you get the AEM cam gear, you can also advance the timing. So, what would be the major differences between the two? If you're just looking to advance the timing, then wouldn't the cam gear be a better way to go? You wouldn't have to worry about being without your ECU. You could change it back yourself, and so on. I know JET also programs your ECU to work with your other mods.
I guess what I'm getting at is, would both of these mods work together, or would it be better to go with one over the other?
Old Jan 29, 2003
RedDragon333's Avatar
Quote
[hr]Originally posted by: zetaR
I guess what I'm getting at is, would both of these mods work together, or would it be better to go with one over the other?[hr]
I would think that it would be best to work them together since your dealing with two differnt types of timing advancment if you wanted to get maximum performance out of the mods. Plus you have the opportunity to adjust a few other things with the JET mod so if its one or the other i would go with the ECU upgrade
Old Jan 29, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
You are talking about 2 completely different things.... the cam gear adjust CAM TIMING which effects when the intake/exhaust valves open and close.... The ECU controls IGNITION TIMING, so I imagine that the JETCHIP would be able to change the ignition timing since that is something electrical, where the cam timing is something mechanical. Hope this helps... later!
Old Jan 29, 2003
zetaR's Avatar
Quote
[hr]Originally posted by: IDQcivic
You are talking about 2 completely different things.... the cam gear adjust CAM TIMING which effects when the intake/exhaust valves open and close.... The ECU controls IGNITION TIMING, so I imagine that the JETCHIP would be able to change the ignition timing since that is something electrical, where the cam timing is something mechanical. Hope this helps... later![hr]
Ahh, I was wondering about that. I was thinking that they may control the timing on two different things. That answers my question. Makes sense now. [IMG]i/expressions/beer_yum.gif[/IMG] for IDQ.
Old Jan 29, 2003
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
If you advanced ignition and cam timing wouldnt that kinda cancel each other out???
Old Jan 29, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Advanced ignition timing and retard the cam timing is the best way to go!
Jet Ecu upgrade got me into the 15.7's but You can't use
advanced ignition timing with N2O, so I have to run dual ECU's
I switch back and forth for daily driving chipped and stock ECU
when I am at the track and going to run N2O
carid
Nov 7, 2015 01:46 AM
Misfit2613
Jul 30, 2015 09:49 AM
Theshwartz35
Jul 17, 2015 11:13 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Ccoop87
Jul 9, 2015 03:26 PM
