Need Help!!! Problem with my face gauges
Old Jan 23, 2003
Jodster's Avatar
Post Whore General
I've got indiglow face gauges that change to 6 differents colors. I've have them for about 9 months now with no problems. On my way home from my buddies house as I was pulling into my street 20 minutes ago my face gauges went out. The needles still glowed, but the gauges where not. I turned off my parking lights and turned them back on. The gauge came on for about a second then turned off. Whats wrong with them? Is it a fuse or is it a wire? I need to fix it tomorrow before I go to work(I work third shift) or I'll have to take them off. Any ideas?
Old Jan 23, 2003
civicvtec1ps's Avatar
Search and Learn
fuse.
Old Jan 23, 2003
Jodster's Avatar
Post Whore General
ok any idea which fuse it would be? Is it under the hood or under the dash?
Old Jan 23, 2003
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
Mine was having the same problem... the wire that attached to the face was shorting out. and burned part of the wire and part of the face. But I got it replaced under warrenty... could also check the wire that connect the wire for the on/off switch to your headlights...
Old Jan 24, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
its not a fuse, if it was a fuse, it wouldnt come on at all... I used to have AC gauges and they were POS< did the same thing you are talking about... I bought some BOMZ gagues that are far superior to the AC guages, the look better, and also have an actual control dial with switch, rather than that cheesy touch pad. Check ebay, thats where I got mine. Later.
Old Jan 24, 2003
scatman's Avatar
Still in the game...
dude, honestly, if you cant get them to work again cut them off. i went thru two sets of the gauges from ac autotechnic and both times the gauges shorted out from the point where the current would come in to the gauge. they look hot but if they keep goin out its not worth the aggrevation
CarStuff
Dec 6, 2020 12:52 PM
pratik05
May 15, 2015 01:54 PM
Lt. Dan
May 13, 2015 12:42 PM
tylerginevan
Apr 27, 2015 12:29 PM
MY01HX
Nov 12, 2001 04:25 PM
