Oil pressure gauge install...
Oil pressure guage install...
I just bought a 3-pod gauge pillar from gauge works. I have 3 gauges (obviously), I'm comfortable with the install of 2 but, I dont grasp the install of the oil pressure gauge too well. I know I need a T-fitting (I did a search on that) but I couldn't find how to actually attach the setup. Whether I unscrew somethign or splice a hose/line...I just don't want to mess anything up. Thanks guys
Joe
Joe
you might want to add weather it's a mechanical or electronic guage. The install is different for the 2 different types of guages.
good luck...
Edit: There is a DIY for the electronic if you search. It's very good w/ good pics
good luck...
it came with a sensor, from the sensor it sends an electrical signal to my Autometer guage, hopfully that helps...dont know if this makes a diff either as far as location of lines...I have a 2002 EX 5Spd
Here you go, I'll have pics on my ride once I install everything.
EDIT * The top two gauges light up in red to match the stock guages. The gauge on the bottom (AF guage) uses LED's to show the AF ratio.
Before I get flames...Yes the top is a boost gauge. I orignally was planning on only 2. But my friend pointed out the fact that NEAD is installing a turbo setup in april so why now get a triple? I only bought the boost gauge now because I do not want to stare at a hole in the pillar.
Xuhme
21
Aug 7, 2023 03:40 PM
jbander
Jun 4, 2015 05:56 PM
jmythngdmb
Jan 24, 2002 03:10 PM
