Canada West Saskatchewan, Alberta, British Columbia, Yukon, NWT
group buy for LED for our gauge cluster ?
Old Jan 19, 2003
tcneo's Avatar
tcneo is an unknown quantity at this point
anyone want to do it ? i found the LED replacement bulb for our gauge cluster, so you don't have to find the condom bulb, lighting gel etc but it's kinda expensive though.. almost $10 USD per bulb + shipping and it's easy to replace
there's 5 bulb (for the gauges alone, not including the other sign for brake, open trunk etc) + 1 (for the odometer) if you want to do it. (not sure about the auto, there should be like 5~6 more bulb for that)
there's several different colour to choose from
and as for the dash console, i haven't had a chance to look into the bulb type yet
Old Jan 19, 2003
dspirit79's Avatar
dspirit79 is an unknown quantity at this point
I"m interested!
Old Jan 19, 2003
murd0c's Avatar
murd0c is an unknown quantity at this point
I'll be down for that!!
Old Jan 20, 2003
Oishi's Avatar
Oishi is an unknown quantity at this point
hmm..thats pretty expensive...
i saw a pic at revscene where some guy just used regular blue LEDs and shone them facing the gauge cluster and it turned out pretty good plus it has that "show" effect on it...
Old Jan 20, 2003
murd0c's Avatar
that is true by the time you know it will will spend $100 but I'm still interested in it get bakc to me~!!
Old Jan 20, 2003
tcneo's Avatar
for a regular blue led, you must add a resistor to it, plus you must do some kind of soldering
it's true that it's way cheaper, but there's also the risk of fying up your led or even your cluster from improper soldering. I'm still searching for a cheaper alternative that is as good as the $10 led bulb with no soldering whatsoever
this is just a preliminary to see how many ppl are interested..
Here you can find more info about the bulb itself, i think the closest match is the first item
bulb no 74 = T1 3/4
Old Jan 20, 2003
Oishi's Avatar
hmm...not really a big risk...an LED only takes up around 10-30mA...simple calculations to get the desired resistor are not that crucial since you have a big discrepancy...so compute using the worst case scenario (meaning calculate for the 10mA current)...use a multimeter with the setting on voltage...check which one is the negative or positive in the gauge cluster...then...
ahh...i'm just speaking from experience...but there is really nothing to it if you know even the basics of DC electronics...
if you do require help or have any questions just ask...
Old Jan 20, 2003
tcneo's Avatar
i'll keep that in mind.. thanks ...
so do u know any good LED retailer in GVA besides radio shack ? i want to get the brightest blue possible so that the red colour on the gauges becomes invisible..
Old Jan 20, 2003
murd0c's Avatar
radio shack is basicly the only place there are really no other places!!
Old Jan 21, 2003
Oishi's Avatar
i got mine for free coz i asked for samples from liteon inc...i always ask for samples and they give em...whats 5 or so out off millions that they develop...at the moment i have received a total of 10 blue leds and about 6 bright white leds...if you just want to buy it and don't want to wait 6 to 8 weeks then just order through future electronics...or any electronics place like intek or something...
oh yah...free is always better than low price...
Old Jan 21, 2003
Oishi's Avatar
Quote
[hr]Originally posted by: murd0c
radio shack is basicly the only place there are really no other places!![hr]
there's a lot of distributors out there for larger companies and they always give out samples...i should know i already mooched a lot of them...oh yah...i got 5 free LCD screens similar to the cellphone ones but i burnt out most of them..now i have one that works...spells out my name, car, temperature and battery voltage...
soon to be added to the car...
Old Jan 21, 2003
murd0c's Avatar
man thats not bad how were you able to hook that up?
when ever I try looking for led's or bulbs such as hyper white running lights and turn signals!! I can't find anything!!
Old Jan 21, 2003
toastyghosty's Avatar
toastyghosty is an unknown quantity at this point
Quote
there's tons of places like Active Components, used to be on marine drive, now it's moved to 1st and boundry i think...
places like radio shack are expensive in comparison if you're buying large quantities, however if you're buying like say a 100 resistors or led's etc etc places like Active or other suppliers will be cheaper.
Old Jan 21, 2003
Oishi's Avatar
Quote
[hr]Originally posted by: toastyghosty
Quote
places like radio shack are expensive in comparison if you're buying large quantities, however if you're buying like say a 100 resistors or led's etc etc places like Active or other suppliers will be cheaper.[hr]
low quantities like that (resistors) they'll just give it for free...they might charge you for leds though...
Ma213802
May 18, 2015 07:01 AM
SpoonSportsd17a
Nov 24, 2001 12:43 PM
inca
Nov 13, 2001 08:23 PM
