Jdm H22a or JDMB18c Gsr for civic hb??
Old Jan 14, 2003
HeartbreakkiD's Avatar
HeartbreakkiD is an unknown quantity at this point
i just bought a used civc hb without engine in there, the guy sold it to me for 4 hundred dollar!!! cash!!!
now i want to start my project...and start doing some research..just wondering which one better?? h22 or b18?? guys please give me some opinion..and i dont like someone talk shxt about my english...i just want u guys give me some opinion...peace~~
Old Jan 14, 2003
VTECTypeR's Avatar
Well I would go with a B18c just my opinion
Old Jan 14, 2003
RyzRocket02's Avatar
RyzRocket02 is an unknown quantity at this point
Personally, I prefer the B's. But the difference is more or less nominal. However, I know you gotta start slicing the bay with the H22. I dunno if it's the same with the B18, but I don't think so. I'm not an engine expert, so you might want to just ignore me.
Old Jan 14, 2003
cambo's Avatar
I wish I was asian
i'd do a B20c swap instead... all the glory of the b-series vtec, with the potential of more displacement than the GSR
BTW: b series parts will probably be cheaper than the h series parts.....i think...
info on B20 swap
B18c swap info
generally will be a good reference for you.
Old Jan 14, 2003
phlipsidez's Avatar
phlipsidez is an unknown quantity at this point
I'd go with the prelude's H22. just to be different from all the B swappers.
Old Jan 14, 2003
cambo's Avatar
I wish I was asian
Quote
[hr]Originally posted by: phlipsidez
I'd go with the prelude's H22. just to be different from all the B swappers.[hr]
how many b20z or b20c swaps have you seen in real life?
me..none so far
Old Jan 14, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
yea you could just drop a 440 in it [IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 14, 2003
XxJDMCivicxX's Avatar
JDM B18C would be the B18C with 210hp with 138 lb-ft of torque, Diplacement: 1797cc, redline 8900, JDM H22A would have 220hp i think not to sure about the all specs though. I would say JDM B18C.
Old Jan 14, 2003
mrdan4548's Avatar
mrdan4548 is an unknown quantity at this point
i have two friends that have done this swap, the guy that did this into his hb had to cut away some parts of his frame to keep ac and powersteering. But man that thing hauls AZZZ in a hb. My friend that owns a shop acutally did it to a civic cpe, his prelude motor is stroked to a 3.0l hes got it in his race car but the motor is still being worked on right now. I say go with the h22, no one can tell its a prelude motor unless they look at the engine code. Other than that just tell everyone its an si motor.
Old Jan 14, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
First of all... what year is it? I'll assume it's a 5th or 6th gen. I would say B because there's tons of parts. You could also look at a B18B and boost the hell out of it. The Non-VTEC engine is better for turbocharging. But it depends which way you want to go.
Old Jan 14, 2003
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
H22 is too big for a daily driver.
and to answer your question: Neither.
http://www.importbuilders.com/block.html
http://www.importbuilders.com/cratedmotors.html
Example:
Description: "I want the best." This is Import Builders favorite block. It revs higher and has slower piston speed, slightly than its B18A/B cousin. This block features the following details:
Iron Sleeves for total strength and durability
IB Spec Wiseco Pistons, JE pistons, or Arias Pistons. You choose!
Eagle Rods or Probe Rods
Bore, Hone, Hot tank, Deck (if nec)
Balanced Crank
Polished Crank
All new Bearings & Thrusts
All new seals, and Oil pan Gasket
New VTEC oil pump
New VTEC water pump
LS/VTEC Oil line Kit with all fittings
Compressions come in 9:1, 9.4:1, 10.5:1, 11.8:1, 12:1, 12.5:1. 12.8:1, 13:1
Price: $3950 Shipped. Want to rev it to 9600 RPM all motor? Pick this one.
Old Jan 14, 2003
mohawkboom's Avatar
well that depends on how much aftermarket modification you intend on doing?.... H22a's have oil burning and are historically not as reliable of bullet proof as the B series engines...it's also a fair chunk heavier and will cause your car to be too front heavy..(great fro dragging.. kind of negtive for handling)..
If you plan on adding a turbo.. definately a B18B 1.8 non vtec..it's the most bulletproof honda engine on the market. and vtec is of no advantage when you have boost and all that torque low down anyhow...
If you wanna be one of the few....get a B20z and B16 heads and a GSR computer but don't think of boosting it or running nitrous because the B20 blocks can't handle F/I all too well...
Old Jan 14, 2003
HondaGuru's Avatar
in a hatch, you will have to chuck the AC and power steering. ie no good for a daily driver, less your super harcore... which i dont believe to be the case here. dont get me wrong, my friend has a 92 Si hatch with an all motor H22A that pulls high 12s, but against, its not his only car. He has a turbo GSR for that.
Old Jan 14, 2003
RedDragon333's Avatar
Quote
[hr]Originally posted by: XxJDMCivicxX
JDM B18C would be the B18C with 210hp with 138 lb-ft of torque, Diplacement: 1797cc, redline 8900, JDM H22A would have 220hp i think not to sure about the all specs though. I would say JDM B18C.[hr]
if it where my HB i would do this swap and make it a CTR
Old Jan 14, 2003
HondaGuru's Avatar
in case i was too subtle in my previous approach... GETTING A JDM ENGINE IS A WASTE OF MONEY.
that is all.
Old Jan 14, 2003
mohawkboom's Avatar
Quote
[hr]Originally posted by: HondaGuru
that is all.[hr]
Bigtime.. most yes MOST JDM engines are high mileage beaten to hell engines..often with mish mash parts and part number sequences that don't match.. for the price you can take a USDM engine *** a few bolt-ons and have more power for less money.
N/A.. B20 Frankenstein..
Turbo B18b [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 14, 2003
HondaGuru's Avatar
Quote
[hr]Originally posted by: mohawkboom
Quote
that is all.[hr]
Turbo B18b [IMG]i/expressions/face-icon-small-smile.gif[/IMG][hr]
Description: "I want it to say B20 on the block to scare people." Regular CRV blocks crack running higher than 12.6:1 or so compression. Sleeve it, them make it 13:1 and get the most HP possible on the street! This block features the following details:
Balanced Crank
Polished Crank
New VTEC oil pump
New VTEC water pump
Price: $3650 Shipped.
Description: "I have a LS/VTEC." A saying that is now associated with "my car is fast." Hopefully, because of Import Builders. This block features the following details:
Balanced Crank
Polished Crank
New VTEC oil pump
New VTEC water pump
Price: $2500 Shipped.
Description: Annihilator Block Packages are out! These are what we believe to be the most reliable, strongest blocks in the industry. These blocks are built to take punishment. The blocks include these features in addition to all the normal block features..
Race Coated IB Spec pistons. Not just a top ceramic coating...no way! This is the REAL DEAL. Just like TOP FUEL does to their pistons, from the same people! This block can take the heat folks. Let there be no doubt.
Eagle Rods or Probe Rods with upgraded ARP bolts
A new sleeving process featuring a closed deck that is vented. This is the ultimate in block strength. Go ahead! Turn up the BOOST!
Price: ADD $850 to the price of any block package that is already sleeved. This is noted by this sign: (**) ADD $1780 to any block that is not already sleeved. There is no ** next to these blocks...
Old Jan 14, 2003
mohawkboom's Avatar
I didn't say LS/vtec..I said B18b [IMG]i/expressions/face-icon-small-smile.gif[/IMG].. no vtec tougher heads.
Old Jan 14, 2003
thank you guys... thanks for the opinion.......i think most of u gonna get b18...
well...i have to check the price......on ebay..
i will get b18 as well....thanks again
Old Jan 14, 2003
Black99Vtec's Avatar
first member with a d16 swap
Black99Vtec should not be trustedBlack99Vtec should not be trustedBlack99Vtec should not be trusted
first off if u are gonna do a b motor you go with a b20 bottom end with a type r head. thats the best combo.
and if you go with a h22 you should find a h23 bottom end with a h22 head. if you use the h motor you will have to carry lead bags in your back hatch to keep the back end down with turning. and it will run mid to low 13's stock! u could go with the b motor and run a lot of boost thro it i have seen them running mid 11's.
Old Jan 14, 2003
HondaGuru's Avatar
Lead bags?!
Shut the hell up. I trust anything you say about as far as you’d get with a seized piston.
Why dont you go ahead and reccomend a 24K gold plated valve cover while you are at it? Talk about a waste of money.
Old Jan 14, 2003
Quote
Lead bags?!
Why dont you go ahead and reccomend a 24K gold plated valve cover while you are at it? Talk about a waste of money.[hr]
LOL, instead of a 24k just get a chromed out one save urself some money [IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 14, 2003
i gaurentee you that the h22 motor is to heavy for that car and it will cause the back end to kick out when u turn. thats why u put the lead bags over each tire in the back. my friend has the swap done to his hb
Old Jan 14, 2003
HondaGuru's Avatar
If that’s the case (and in case you aren’t lying like you do with everything else) then kick him in the nuts for being a moron. Either for thinking he needs lead bags or for screwing up the car so much during the swap that he actually DOES need them.
Please die slowly
Old Jan 14, 2003
HondaGuru's Avatar
Quote
Quote
Lead bags?!
LOL, instead of a 24k just get a chromed out one save urself some money [IMG]i/expressions/laugh2.gif[/IMG][hr]
that would defeat his purpose. lol moneypit.
Old Jan 14, 2003
man...peace man....lol
by the way, i got 95 model hb..
good deal for 4 hundred?? without motor....[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 15, 2003
aznsmtboy's Avatar
aznsmtboy is on a distinguished road
Quote
Since when did the JDM B18C1 come with 210 HP, I know for a fact that the Integra SI-G (JDM integra GS-R) came with 178 HP stock.
Old Jan 15, 2003
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
the usdm B18C1 is more than enough for me however it woulda been better with a C5
dont bother with the H22 unless you know what your doing (which you obviously dont if your asking this question) unless you want your car to have major suspension problems
Old Jan 15, 2003
mohawkboom's Avatar
Quote
[hr]Originally posted by: NeoMagus
dont bother with the H22 unless you know what your doing (which you obviously dont if your asking this question) unless you want your car to have major suspension problems[hr]
The C5 with matching type-R tranny is way different than a GSR.. a GSR with type-R tranny will be faster but at a cost of top speed....the gears on them things are rediculously close [IMG]i/expressions/face-icon-small-smile.gif[/IMG]...
Old Jan 15, 2003
666's Avatar
666
666 is an unknown quantity at this point
B18C5[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
