venom nos fit for our car?
Old Jan 14, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
k i checked performanced center and they said both vcn 1000 and 2000 are custom fit for our car, just wanna know see wat yall think or any comments you have.
Old Jan 14, 2003
Toretto's Avatar
Toretto is an unknown quantity at this point
nos kits fit any car as long as you have the right nozzles, jus dont vlow yourself up!!!
KKAAAABOOM!!!
Old Jan 14, 2003
heh well that sneaky pete doesn't work with ours cause its made for carb cars
Old Jan 14, 2003
Toretto's Avatar
i dont kno toretto used it in his RX-7 haha
Old Jan 14, 2003
Toretto's Avatar
hey my pm is messin up on me for some reason, i got your pm but i cant send anything out
for some odd reason
Old Jan 14, 2003
so wat u prefer, wet? dry? any prep mods before nos? nx? venom?
Old Jan 14, 2003
Toretto's Avatar
i would perfer wet for going turbo, go dry without turbo,
NOS is still a forced induction so you want your car to breathe
the it can. do you have headers any fuel system upgrades??
Old Jan 14, 2003
Toretto's Avatar
breathe the best it can ^_^
Old Jan 14, 2003
gettin the ceramic dc header, not fuel upgrades yet...wat do u prefer. after the header do i need the downpip from header to high flow cat? and after market high flow?
Old Jan 14, 2003
Boosted's Avatar
Boosted is an unknown quantity at this point
I use the VCN-2000 and it is not a custom fit it is made for our cars.
Goto *** Imports and they help you decide which system will work best for you.
Old Jan 14, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
The venom systems take care of the fuel for you (safely at a 50 shot...maybe 55-60) it pulses your stock injectors longer to get the proper fuel you will need by monitoring your o2 sensors. You will need ATLEAST I/H/E, and recommended clutch. Other than that you should be all set at a low shot. The venom also comes with the a/f monitor that will shut the flow of nitrous off if it senses you are running lean. IMO It;s a great setup. the 2000 is completely computer programmable.. A+
Old Jan 14, 2003
mohawkboom's Avatar
it would be a Venow Nitrous kit. not a venom NOS kit..NOS is a company....
Old Jan 14, 2003
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
you dont need ANY additional breathing mods. Nitrous systems are designed from th ground up to work with completly stock cars. Any other mods will just enhance power gains. For example, I was running NOS nitrous dry with JUST an intake for almost a year with NO problems (50 shot). Went through about 25-30 bottles in that time. Also a high flow cat is useless. Thats the LEAST restrictive part of your entire intake/exhaust system. A header and intake are a good place to start, the cat should be LAST on your list.
FOr things that wil make it safer, get an MSD RPM activated window switch, upgraded ignigition/plug wires and use NGK-BKR7e plugs.. NO PLATNUM OR IRIDIUM.
wdit: you should also look into getting an upgraded inline fuel pump with a fuel pressure regulator.
Old Jan 14, 2003
HondaGuru's Avatar
Quote
[hr]Originally posted by: mohawkboom
it would be a Venow Nitrous kit. not a venom NOS kit..NOS is a company....[hr]
beat me to it.
Old Jan 16, 2003
Baghead's Avatar
Baghead is an unknown quantity at this point
Quote
[hr]Originally posted by: Toretto
KKAAAABOOM!!![hr]
um...venom nitrous doesnt have jets, it digitally controls the amount injected i believe.
Old Jan 17, 2003
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
Quote
[hr]um...venom nitrous doesnt have jets, it digitally controls the amount injected i believe[hr]
wrong, venom uses different size nozzles to control the amount of nitrous. They color code them so you don't get mixed up [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jan 17, 2003
Baghead's Avatar
Quote
[hr]Originally posted by: PlatCruiser
Quote
wrong, venom uses different size nozzles to control the amount of nitrous. They color code them so you don't get mixed up [IMG]i/expressions/face-icon-small-wink.gif[/IMG][hr]
heh i think we both wrong, i looked it up venom 1000 is nozzles 2000 is computer controlled.
Old Jan 19, 2003
doh, hehe I should have said the 1000, 2000 is too pricey [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Poopies
Apr 20, 2017 11:36 PM
BreezeNine
Apr 14, 2015 05:41 PM
aus10
Apr 13, 2015 09:26 PM
