What brand and how many octane u put?
Old Jan 13, 2003
dru106's Avatar
ThE CoRRupToR
I use MOBIL gas 91 octane when the price is $1.57 a gallon but 87 octane when its higher price. What about you guys?
Old Jan 13, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
This topic has been beaten to death. Our cars were designed to use 87. Use it
Old Jan 13, 2003
dru106's Avatar
ThE CoRRupToR
I dont know but it seems like 91 lasts longer than 87. Plus wouldnt it cause carbon in the long run on top of the pistons running on low octane?
Old Jan 13, 2003
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
If you really wanted a high octane rating then get Regular gas and go to the local auto parts store and buy some Octane Booster... it will save some money
Old Jan 13, 2003
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
Mid Grade...
Old Jan 13, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
I used to use Chevron 87 and i heard a lot of engine knocking
Now i use 89 or 91 sometimes.... less knocking.
edit:
$1.59 for 87
$1.79 for 91
Old Jan 13, 2003
CapYoda's Avatar
Escaped Convict
thats nuts. this car doesn't need anything over 87. just waste of money IMO.
different gas station does have different gas though it seems.
I just fill up at whatever is the cheapest.
Old Jan 13, 2003
XxSoVeReiGNxX's Avatar
What's Octane???
In New Jersey, we call fuel GAS, and there is usually 3 types: Unleaded, SuperUnleaded, and Premium. 85, 87, & 93 I think.
We only have Sunoco, Shell, Texaco, and Mobil Stations around my area.
Old Jan 13, 2003
Voiceofid's Avatar
End Bringer
Quote
[hr]Originally posted by: XxSoVeReiGNxX
What's Octane???
We only have Sunoco, Shell, Texaco, and Mobil Stations around my area.[hr]
you already said the octane, "85, 87, & 93" basically, the octane rating tells you how much resistance the gas is to compression, usually higher compression cars have to to high octane gas. the integra type-r is recommended to use 100 octane due to it's 11.5:1 compression ratio
the octane around here are 87, 89 and 91. i usually get 87, if i have an extra few bucks, i would get 89...
Old Jan 13, 2003
orso's Avatar
orso is an unknown quantity at this point
chevron 91
Old Jan 13, 2003
Dagooseisloose's Avatar
Dagooseisloose is an unknown quantity at this point
Amoco 89 when Im near my house if im not near my house I stay with the major brands Hess,Shell,Mobil but I try to get Amoco.
Old Jan 13, 2003
n00dleboy's Avatar
n00dleboy is an unknown quantity at this point
Quote
[hr]Originally posted by: dru106
I dont know but it seems like 91 lasts longer than 87. Plus wouldnt it cause carbon in the long run on top of the pistons running on low octane?[hr]
No it's the other way round. If you use higher octane gas than required, you will get carbon build up over a long period of time.
Old Jan 13, 2003
JoeyP's Avatar
JoeyP is an unknown quantity at this point
Quote
[hr]Originally posted by: n00dleboy
Quote
No it's the other way round. If you use higher octane gas than required, you will get carbon build up over a long period of time.[hr]
Maybe..... everyone needs to read up it looks like.
http://www.epinions.com/auto-review-...38FF47F2-prod4
cutting to the end:
"Using a higher octane gasoline in an engine designed for low octane WILL NOT increase it's performance - the octane number is a MINIMUM needed to eliminate detonation, and that's all it is.
In conclusion, the octane rating is a measure of the fuel's ability to CONTROL the burning process (to prevent detonation); it is not a function of burning 'hotter' or 'colder'. And the higher the compression ratio (in the same engine), the higher the octane number needed. "
Old Jan 13, 2003
mattskav's Avatar
mattskav is an unknown quantity at this point
Quote
[hr]Originally posted by: JoeyP
Quote
Quote
In fact this is not true, some cars, like ones powered with the northstar and other GM's, will take advantage of the reduced knocking and advance the timing yielding more power. Other cars such as hondas will actually loose power with higher octane because of the lower power density. See C&D for an independent test.
cutting to the end:
In conclusion, the octane rating is a measure of the fuel's ability to CONTROL the burning process (to prevent detonation); it is not a function of burning 'hotter' or 'colder'. And the higher the compression ratio (in the same engine), the higher the octane number needed. "[hr]
Old Jan 13, 2003
TeLLy's Avatar
Yes, it's an Acura EL
I use whatever I can afford. I don't really notice a difference either way, but I feel like a big man filling up on Sunoco 94 on big paydays.
Old Jan 13, 2003
VtecDude's Avatar
VtecDude is an unknown quantity at this point
Chevron and I could have sworn it was 92. But it seems as though it is 91. Nothing but the best for my car, especially when its free. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jan 13, 2003
RedDragon333's Avatar
Cheveron w/ Techron 93 octane
Old Jan 13, 2003
Quote
[hr]Originally posted by: RedDragon333
Cheveron w/ Techron 91 octane[hr]
Old Jan 13, 2003
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Premium gas, iridumb spark plugs, red line super magic wonder oil...
People sure like pissing there money away for no reason. Use 87 octane...if you get predetonation with that, there's something more serious wrong. If you absolutely feel the need to replace your plugs before they need to be, use copper. Copper plugs are cheaper and perform better. Oil...why use expensive synthetic if you're just going to change it as often? Use Motorcraft of Valvoline 5w20...and change it often. Don't get me started on $10 Mobil 1 oil filters.
Old Jan 13, 2003
Cyko's Avatar
Cyko is an unknown quantity at this point
Yeah ppl sure do like to **** their money away.
Civics are set up to be able to use 86 octane.
If you are having problems with 87 then you
better go get yer engine checked cuz you have some
problems.
Old Jan 13, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
the best.....
Old Jan 13, 2003
FALKEN's Avatar
Civicforums Junkie
Mobil with 87octane...
It doesn't matter to me much because it's not a HP car
Old Jan 13, 2003
Cali's Avatar
Cali is an unknown quantity at this point
Arco, 87 octane
Old Jan 13, 2003
Mystix's Avatar
Mystix is an unknown quantity at this point
Quote
What's Octane???
LOL funniest thing i heard all day, "In New Jersey, we call fuel GAS". [IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 13, 2003
dragoon's Avatar
chevron 87 octane, walmart brand motor oil and filter changed every 2500. $7/quart motor oil and $10 oil filters just aren't my thing
Old Jan 13, 2003
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Only the best for my Civic, good old Chevron 92 octane but my mileage lately has been sucking better get an oil change and get some fuel injection cleaner. Its that or since in Oregon they pump your own gas and they are not filling it up as high as I did in Arizona because I got more miles a tank when I lived there :-) plus my rims seem to affect it a little too.
Nick
Old Jan 13, 2003
civicex2002's Avatar
civicex2002 is an unknown quantity at this point
Our cars were deisgned to use 86 octane so running 87 is using upgraded fuel.
Old Jan 14, 2003
JohnnyLee's Avatar
7thgen guh chee
91 Chevron with Techron
Old Jan 14, 2003
AR's Avatar
AR
e-married to daydreamer
premium 93 octane.
only shell, i dont support amoco aka now "bp". mobil is way too expensive otherwise.
i am concidering changin to 87 but i have not had the motivation. wherever i go, i always make sure their is a shell close buy if im low on fuel.
i dont concider myself pissing money away. i concider someone purchasing a civic thinking theyll get a fast car, pissing money away.
Old Jan 14, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
you really don't need that high octane, useless. Use Exxon 87 here!
