How often should you clean your intake filter?
Old Jan 10, 2003
IronFist's Avatar
I installed my FIPK about 2000 miles ago. How often should you clean it with that kit they give you? Is it hard to do? How long does it take?
Thanks,
IronFist
Old Jan 10, 2003
sspem2's Avatar
em2
go to your local auto store and pick up k and n filter cleaner for $15 and clean it every other oil change. you might want to search cuz i have helped people on the same question.
Old Jan 10, 2003
GhettoCivic's Avatar
GhettoCivic is an unknown quantity at this point
I have an injen intake, with a K&N style filter, and on the filter recharging kit it gives some huge number like 50,000 miles before you should clean your filter. I don't rememeber exactly, cuz I'm at the dorms right now and its in the garage at home, but it said something like the dirt particles that accumulate on the outside of the filter actually help the filter. Cleaning the filter frequently is not recomended and is not good for the filter.
Old Jan 10, 2003
CarbonFly's Avatar
I clean mine every 10,000 miles............well it's time for its first cleaning
Old Jan 10, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
When it gets dirty.........lol.....
Old Jan 10, 2003
zetaR's Avatar
zetaR is an unknown quantity at this point
Local performance shop I go to recommends that you clean it every other oil change.
Old Jan 10, 2003
SOHCScreamer's Avatar
SOHCScreamer is an unknown quantity at this point
whenever i wash my car i take the hose to it. thats the way i clean it.
Old Jan 10, 2003
Blk4blk2K1's Avatar
Retired Super Mod and STILL Pimpin' Yo Mama
Blk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to behold
Quote
[hr]Originally posted by: SOHCScreamer
whenever i wash my car i take the hose to it. thats the way i clean it.[hr]
You don't remove it first? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 10, 2003
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
your FIPK (like mine) came with instructions regarding cleaning the million mile warrantied K&N filter it came with. i dont remember exactly when it should be done, it says so in the instructions. your FIPK should have come with a "recharger" kit that has cleansing solutionis. it doeant look that hard to do, pretty simple i think.
Old Jan 10, 2003
Quote
[hr]Originally posted by: Blk4blk2k1
Quote
You don't remove it first? [IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
nope. hi pressure hose from all angles. every once in a while i take it off wash it out from the inside.
Old Jan 10, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
The instructions from the cleaning kit say never wash from the outside because it presses dirt down into the fibers. So you may want to rethink the high pressure hose method.
I cleaned mine out after about 10000 miles and it was pretty dirty. I think 2000 is probably a bit early though. You can prolly wait a while. I also recommend the aerosol cleaning kit as opposed to the pump spray one... it's easier to use. They both have the same stuff in them, but one sprays constantly (aerosol) the other one you need to keep pumping.
Old Jan 10, 2003
pdxbiker's Avatar
pdxbiker is an unknown quantity at this point
I would say every 20 - 30k miles because washing it too much will cause the cotton fibers in the filter to diminish. Of couse all of this depends on how dirty the air is but I guess you can every 10k miles. They actually have something to measure air flow to determine if you need to wash it our not.
Old Jan 11, 2003
Nuts's Avatar
Nuts is an unknown quantity at this point
every day
Old Jan 11, 2003
dragoon's Avatar
every 6 months
Old Jan 11, 2003
neoretromax's Avatar
neoretromax is an unknown quantity at this point
ive had my K&N fipk on for 6500 miles now and havent cleaned it yet and i just started noticing a little hesitation and its not as loud as it used to be at wot. probably around 6000 miles is my guess to clean it. i better go clean it.[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Jan 19, 2003
i just cleaned my k&n cone at about 7000 miles, but read on the instructions that it should be cleaned every 50,000 miles. anyway i noticed a lot better throttle response after cleaning it!
Old Jan 19, 2003
alphabios's Avatar
alphabios is an unknown quantity at this point
Quote
[hr]Originally posted by: dragoon
every 6 months[hr]
This is what I have heard
Old Jan 20, 2003
GPMarzan's Avatar
GPMarzan is an unknown quantity at this point
speaking of filters, i still have to clean mine
Old Mar 4, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Quote
Quote
Quote
nope. hi pressure hose from all angles. every once in a while i take it off wash it out from the inside.[hr]
d00d! Washing it that way will surely blast all the oil off your air filter. The oil helps filter out the really small stuff. The recharge stuff w/ the K&N kits is oil. Why do you think you have to spray that back on after you use the cleaner? Re-oil that filter buddy, otherwise it's not doing it's job.
Old Mar 4, 2003
Voiceofid's Avatar
End Bringer
i recharge everytime i remember to, or every oil change
Old Mar 5, 2003
Grey's Avatar
DIY King
K&N says check every 30,000 miles if it's dirty and clean every 50,000 miles regardless of cleanliness. That's probably good advise for K&N air filters that are within stock assemblies. If the filter element is exposed (like in a CAI, or SRI) then I would clean it when it's visibly dirty.
Old Mar 5, 2003
chirpin2k2civic's Avatar
chirpin2k2civic is an unknown quantity at this point
oil that baby up when it "looks" dirty
Old Mar 5, 2003
slystad810's Avatar
Agreed. When it's dirty.
wasa67
Jun 27, 2015 01:47 AM
Reverb2005
Jun 26, 2015 06:22 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
ORskier
May 7, 2015 04:54 PM
carid
Apr 30, 2015 07:00 AM
