rear disc brakes suspension sqeaks
Old Jan 7, 2003
stackz's Avatar
stackz is an unknown quantity at this point
I don't know if you 7th gen guys have rear discs or not so I figure I'll go out on a limb with this one...
I installed rear discs that I robbed off a 97 del sol on my 98 ex over christmas and put 99-00 civic si e-brake cables and brake lines on them (since the delsol units were cut sigh)
anyway, I figured the suspension would settle after a week or so...but no...I still get the "scricky scricky" sound when I go over bumps...I know what joints are making the noise as I've sprayed WD-40 on them all systematically until it went away but the WD-40 doesn't last long and it comes back...not cool.
anyone else done this swap or something similiar and had a problem like this?? any suggestion on how to fix it?? thanks...
-stackz
Old Jan 7, 2003
clownprince's Avatar
Ricerus Maximus
My stock bushings squeaked and I put some dry lube on them and no more squeak.
Old Jan 7, 2003
stackz's Avatar
dry lube?? explain what is this dry lube?? heh and do I have to take apart the suspension again to do this??
-stackz
Old Jan 7, 2003
Zzyzx's Avatar
Autocross Junky
some high temp Lithium grease should do the trick, pick some up at an auto store. at the very least it'll last a whole lot longer then the WD-40
Optimus34
May 25, 2015 11:52 PM
rhvic
May 22, 2015 03:06 PM
Aball93
May 16, 2015 10:11 AM
Broadbeb
May 14, 2015 09:49 PM
Andy
Dec 29, 2001 07:32 AM
