Steering noise
Old Dec 31, 2002
StealthBlack's Avatar
StealthBlack is an unknown quantity at this point
Steering noise
I have a simple problem, i think, and need some help. When i turn my steering wheel all the way to the left or right i hear a whine/squeek noise under the hood. Any thoughts or suggestions on what might be causing it?
Old Dec 31, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
It's normal.
If it's making a lot of whining when it's not ALL the way, then you may have a faulty Power Steering Pump.
Old Dec 31, 2002
Just curious, why does it make that noise?
Old Dec 31, 2002
XxJDMCivicxX's Avatar
Well my friend told me it was something about two piece hitting each other when you have fully turned the wheel to the max left or right not sure though. I know it's normal though.
Old Jan 2, 2003
TeLLy's Avatar
Yes, it's an Acura EL
Normal, but should be avoided. That noise means something bad is happening. I'm pretty sure your Civic manual says something about not holdin the wheel all the way left or right because it damages the power steering pump.
Old Jan 2, 2003
Pinoy3LeR's Avatar
Pinoy3LeR is an unknown quantity at this point
check for leaks,might be a problem in your power steering pump
15EXCoupe
Jul 30, 2015 12:59 PM
breanna_17
Jul 21, 2015 04:01 PM
mokkush
Jul 14, 2015 04:05 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
06Si_Girl
Jul 12, 2015 12:08 PM
