Ohm Load?
Ohm Load?
What kind of ohm load will (2) Dual 6ohm Voice Coil Subs present to a Mono amp if wired for low impedance by connecting the voice coils of each driver in parallel (+ to +, - to -) and the drivers themselves in parallel (+ to +, - to - )?
also what kind of load will (2) 3ohm 6.5" Midbass Drivers present to a 2-channel amp?
The subs will be 1.5 ohm. The midbass driver on a 2 channel amp I assume would be hooked up in stereo, so it should a 3 ohm stereo load. Just be careful when running your subs at 1.5 ohm to your amp. Make sure your amp is 1.5 ohm mono stable. They are alot of companies out there that claim there amps to be 1 ohm stable but its 1 ohm stereo stable. Meaning they are only 2 ohm mono stable. Power supplies in amps have a tendenacy to smoke real quick when given an ohm load they cant handle. Dont worry about the midbass drivers tho. When running a 3 ohm stero load, almost every amp on the market should run those without any concerns.
Ok thanks for the help... That's what I was looking for [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
BTW: Nice Car Custom2k1 I like the graphics they flow nicely on the car... best 2k1 i've seen in a while
All Show No Go Sedan
If anyone ever wonders what OHM load they will get in wiring, JL Audio provides an excellent tutorial on their web site. Here's the link...
JL Audio On Subwoofer Wiring
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
JetsterDajet
52
May 8, 2016 12:11 AM
JMKendrick
Sep 16, 2015 06:17 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
