Ohm Load?
Old Dec 23, 2002
scrible's Avatar
scrible is an unknown quantity at this point
Ohm Load?
What kind of ohm load will (2) Dual 6ohm Voice Coil Subs present to a Mono amp if wired for low impedance by connecting the voice coils of each driver in parallel (+ to +, - to -) and the drivers themselves in parallel (+ to +, - to - )?
also what kind of load will (2) 3ohm 6.5" Midbass Drivers present to a 2-channel amp?
Old Dec 23, 2002
alex053's Avatar
Two dual 6's in parallel will give you 1.5 ohm. two 3 ohm midbass will give you the same impedence
Old Dec 24, 2002
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
The subs will be 1.5 ohm. The midbass driver on a 2 channel amp I assume would be hooked up in stereo, so it should a 3 ohm stereo load. Just be careful when running your subs at 1.5 ohm to your amp. Make sure your amp is 1.5 ohm mono stable. They are alot of companies out there that claim there amps to be 1 ohm stable but its 1 ohm stereo stable. Meaning they are only 2 ohm mono stable. Power supplies in amps have a tendenacy to smoke real quick when given an ohm load they cant handle. Dont worry about the midbass drivers tho. When running a 3 ohm stero load, almost every amp on the market should run those without any concerns.
Old Dec 24, 2002
scrible's Avatar
Ok thanks for the help... That's what I was looking for [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
BTW: Nice Car Custom2k1 I like the graphics they flow nicely on the car... best 2k1 i've seen in a while
Old Dec 25, 2002
Aznnp77's Avatar
All Show No Go Sedan
Aznnp77 will become famous soon enoughAznnp77 will become famous soon enough
If anyone ever wonders what OHM load they will get in wiring, JL Audio provides an excellent tutorial on their web site. Here's the link...
JL Audio On Subwoofer Wiring
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
JetsterDajet
52
May 8, 2016 12:11 AM
speedlever
Sep 24, 2015 07:18 PM
JMKendrick
Sep 16, 2015 06:17 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
