sleeving the block vs block gaurd
Old Dec 20, 2002
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
can anyone tell me what would be cost effiecent for an LX plans are NA, maybe pistons and rods in the future, either custom or otherwise and a little nitrous use if I decide to put the kit on
Old Dec 20, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
i would think sleeving the block would be more for forced induction than an NA motor. The massive increase in cylinder pressure (in the combustion chamber) would definitely call for sleeves. i dun think sleeving the block would be necessary for NA application since there will not be a dramatic increase in cylinder pressure....so if you plan on later going with nitrous i'd (personally) sleeve for precaution and also to up the shot for extra advantage[IMG]i/expressions/beer_yum.gif[/IMG]
Old Dec 21, 2002
OMega's Avatar
OMega is an unknown quantity at this point
Yeah, both are a good idea to us. Block gaurd is a must for force induction. Sleeving is also good with certin types of ring and pistons. I can't rember off the top of my head but there certain metls (spelling need to sleep...) that hold up good under boost but cause extra wear on normal cylinder walls.
Quote
[hr]Originally posted by: Jon
i would think sleeving the block would be more for forced induction than an NA motor. The massive increase in cylinder pressure (in the combustion chamber) would definitely call for sleeves. i dun think sleeving the block would be necessary for NA application since there will not be a dramatic increase in cylinder pressure....so if you plan on later going with nitrous i'd (personally) sleeve for precaution and also to up the shot for extra advantage[IMG]i/expressions/beer_yum.gif[/IMG][hr]
Old Feb 6, 2003
mani's Avatar
mani is an unknown quantity at this point
Hey what does sleeving the block mean?
Thanks [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 7, 2003
chefjnr's Avatar
chefjnr is an unknown quantity at this point
do they make block guard for the D17 01 civic ex?
Old Feb 7, 2003
REDVIC's Avatar
One of few in the 13's
REDVIC is an unknown quantity at this point
Quote
[hr]Originally posted by: chefjnr
do they make block guard for the D17 01 civic ex?[hr]
Same question... Thanks!
Old Feb 7, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
Sleeving a block is making the cylinder walls stronger but putting in better material. what they do is bore out the old one to with in a few thousands of an inch. heat it up to about 500 degrees C, this expands the metal, and the put the new cylinder wall, that is a few thousands of an inch bigger then what they just bored out. normaly this wouldn't fit but thats why they heat it up, it is now expanded and the new cylinder wall is smaller then the holes they bore and they slide it in and let it cool down the metal goes back to the normal bore size and it is super tight fit now with much stronger material that can handle increased pressure. Thats the quick and dirty version of it.
styles234
21
Nov 19, 2019 07:23 AM
Tedverseti
Sep 29, 2015 05:41 PM
Bruce2
Sep 27, 2015 08:45 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
