Adventures with Expanding foam!
Old Dec 14, 2002
fonto's Avatar
The LA Clipper
Ok so I did a lot of stuff today I was able to install my second two Shivas, so now I have 4, and I got it all hook-uped. I only got to listen for a lil, but it sounded amazing (atleast the subs did). The spl was way more then I expected and it sounded nice. I also jacked up the gains on my tweets and woofers, I have them set seperatly so I need to reset them so that they sound better with my subs. The highs are kinda getting drowned out right now [IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Anyway, My ish was rattling like crazy!!!! My back dash was rattling like never before So I got some more expanding foam for my car, and so I sprayed up where my rear fill used to be. I put some t-shirts on my subs to protect it from drips...but like an idiot, I stuck my head in the trunk to look up the holes, and i got some of it in my hair I also have the stuff all on my hands because I didn't wear gloves! And the moral of the story is to wear gloves and watch your hair with expanding foam [IMG]i/expressions/face-icon-small-mad.gif[/IMG] i should have learned my leason the last time when I sealed my trunck closed and the locking mechanism with foam. I should not be allowed to touch any moving mechanisms in my car
By the way, I think my biggest rattling problem is coming from my third brake light hitting the back window...and suggestions on how to stop this? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
I put foam under it, but I don't want to put it on top because it would kinda look dumb...anywayzzzz[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Dec 14, 2002
BumpinCivic2k1's Avatar
BumpinCivic2k1 is an unknown quantity at this point
take your rear deck apart and stuff cloth or spray some of your foam back there, all on the frame, and put it back together.
Old Dec 15, 2002
fonto's Avatar
The LA Clipper
Quote
[hr]Originally posted by: BumpinCivic2k1
take your rear deck apart and stuff cloth or spray some of your foam back there, all on the frame, and put it back together.[hr]
Good idea dude, I thought of something like that right after I posted my story. I don't have rear speakers so i can just stuff some old t-shirts up there. I won't even hate to take that thing out because it is a biotch!!
Old Dec 15, 2002
mohawkboom's Avatar
I cut out a small piece of sheet metal under it and used hot glue [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 15, 2002
LudlamTheory's Avatar
i boogie for the raindrops
get a little strip of foam and put it between the whole rear dech and dash... if you do it neatly itll look good
Old Dec 15, 2002
FaintReality's Avatar
FaintReality is an unknown quantity at this point
It's a bitch stopping rattles on a car with a trunk. In my previous 00 celica and my current RSX-S the rattles are a bare minimum in which are easily stopped with weather stripping.
Old Dec 15, 2002
fonto's Avatar
The LA Clipper
I will try some things and see what happens. Thanks for the advice yall [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 15, 2002
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
actually, its not the deck hitting the window, its the little flap inside the third brake light vibrating against the red lens, i have the oem spoiler and the origional 3rd brake light was disconnected, so all i did was stuff some paper towels between the flap and the bottom of it, uh, that was a little confusing, well, if you still have the oem 3rd brake light, take it out, turn on your system, stick your finger in the hole, and youll know what i mean, you can see it vibrating if you look closely, and with your finger you can make it stop, so just try putting something up in there, that vibration is totally gone now, but the others? uhh, yeah ok, sure
Old Dec 15, 2002
WhiteRabbit's Avatar
heh, you think expanding foam is bad, ive lived breathed slept in and eaten fiberglass resin [IMG]i/expressions/face-icon-small-wink.gif[/IMG] expanding foam is sticky isnt it... never wulda guessed!
I carpeted my rear deck. matches my floor and kicks, and c pillars, everything, basically, makes the taillight look a ton sleeker, and i cant hear it when the rear deck hits teh window anymore. perfect.
Old Dec 15, 2002
fonto's Avatar
The LA Clipper
Quote
[hr]heh, you think expanding foam is bad, ive lived breathed slept in and eaten fiberglass resin expanding foam is sticky isnt it... never wulda guessed![hr]
Yes, in fact, I still have that ish on my hand...I look like I have athletes hands because of the way it is peeling!!!
Old Dec 16, 2002
KaZeLL's Avatar
KaZeLL will become famous soon enough
watch where you put that foam..heard some bad story's about installers using to much and it expands so much that pushed out the 1/4 panel..lol. NOW that sucks!
Old Dec 16, 2002
fonto's Avatar
The LA Clipper
Quote
[hr]Originally posted by: KaZeLL
watch where you put that foam..heard some bad story's about installers using to much and it expands so much that pushed out the 1/4 panel..lol. NOW that sucks![hr]
I had some problems, but whatever
Old Dec 17, 2002
VNlilMAN's Avatar
The Standard One
damn you got 4 shivas in your car? gotta listen to it one day...
Old Dec 17, 2002
fonto's Avatar
The LA Clipper
It is a lil too much bass, but it is cool to have the extra bump
Old Jul 18, 2003
orion_squall's Avatar
what???
expending foam has the power to push out the 1/4 panel???
those panel are made of steel isn't it??? when the foam expend it can push that outward???
Old Jul 18, 2003
CIVICONBAGS's Avatar
CIVICONBAGS is an unknown quantity at this point
i got a stuffed beany baby and squished it inbetween my rear deck and window =D works for me
Old Jul 18, 2003
expending foam is very sticky, is it really good to use it?
because after using, there is no way to remove
Old Jul 18, 2003
fonto's Avatar
The LA Clipper
Damn, talk about reviving an old thread
Old Jul 19, 2003
how about the answer for using expanding foam?
Old Jul 21, 2003
VNlilMAN's Avatar
The Standard One
the one i got is waterbased and you could remove it. it isnt easy but its not impossible either.
and arent dynamant and other sound deadeners very sticky anyways? same thing. and if you do a good job with the foam, you probably wont even be able to see it. i used white foam on my black car so you could kinda see it
Old Jul 21, 2003
yess, expanding foam can push out the rear 1/4 panel. it can also save yoru car in an accident becuase of it.
my buddy unloaded about a can and a half in each of his rear quarterpanels, and got hit by another car square into the panel, the car was going 30 miles per hour.
it looked like someone chipped a golfball into an otherwise stock car.
so foam has the power to make yrou car REDICULOUSLY strong and solid
Old Jul 21, 2003
alex053's Avatar
yup...i can bang on my drivers side quarter panel and it wont dent or make a move
Old Jul 23, 2003
OMega's Avatar
OMega is an unknown quantity at this point
I was wondering about how much if any of weight increase you'll have.
Old Jul 23, 2003
none, its like 99% air
martinsmartin
Aug 15, 2015 07:34 PM
cukaracha
Jul 17, 2015 05:48 PM
Ben
Jun 14, 2002 12:23 PM
