tsunami sides and rear w/OEM front lip?
will the front lip and sides line up like this __ _______?
or will the sides be alot lower then the front lip?
anyone with the sides, if you could let me know if it is a lot lower compared to the stock sides. thanks.
p.s. i searched but noone talked about matching the front lip with the tsunami sides.
DIY King
I have the Tsunami bumper and I think they made the sides to line up with the rest of their kit. I've seen some pictures of the full Tsunami kit before (high res, different angles), and I remember this to be true. How low does the OEM lip go? You know that front black plastic "spoiler" that's on there? Did you take that off to put on the OEM lip? How does it compare to the bottom of that rubber piece? My Tsunami goes as low as the metal frame underneath that supports the radiator. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
ok, thanks alot. it should line up pretty well then. the OEM front spoiler adds maybe a quarter of an inch onto the front. it just sticks and bolts onto the front bumper. if the sides line up with the metal on the bottom of the radiator, then it should line up fine with OEM lip.
ej8
Apr 13, 2015 06:36 PM
CapYoda
Nov 11, 2001 05:17 PM
