0W-30
0W-30
Has anyone else used 0W-30 Oil yet? Considering it's colder than a witch's titty here, my car spends more time outside than in my nice warm garage and it isn't going to get much warmer until spring, I opted for the better cold starting stuff (vs 5W30). So has anyone else ran it yet, or am I going to guinea pig it? I've got 4 quarts of Mobil 1 going in tomorrow morning.
(I did search, and found no threads about it)
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
sure it will work, but wouldnt you rather have something better, and that wont be all thick on a cold start (ie more engine wear, herder starts, longer time to crank over...)
Hail to the king baby
Quote
[hr]Originally posted by: Boilermaker1
(I did search, and found no threads about it)[hr]
go with Amsoil
Best oil out there
Yes it's thinner. I know that. And according to Mobil Oil, it's better for starting cold. But if all you guys don't think it's a good thing to put in, then I can just go switch it for 5-30 in the morning. It's not in the car yet.
My comment was for the HondaGuru...a thinner oil would be better for your application since it would be thinner at the lower temp than the 5W would be and would start easier but would eventually get to the 30W viscosity.
5w-30 synthetic is perfect for our civic in all weather temps, there is no way you will have to worry about freezing, oil simply cannot freeze, it might get slightly thicker, but it will not get to the point where you will have problems starting or running your car.
pmjr0987
22
Mar 7, 2012 09:57 PM
matt35foley
Dec 16, 2008 06:17 PM
