Sponsored by:
Sponsored by: CARiD
wats the best way to make ur car faster?
Old Dec 5, 2002
KEychain's Avatar
KEychain is an unknown quantity at this point
if ur low on budget
Old Dec 5, 2002
prototype's Avatar
x-factor
providing u did the intake header and exhaust...go nos.....500 for 75 hp.....not a bad trade off...if u didnt do them...do it...u will need those mods if u plan on doing n e thing else to the motor
happy modding
Old Dec 5, 2002
cambo's Avatar
I wish I was asian
get a 24 speed mountian bike and add NAWWS
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Dec 5, 2002
JJJ's Avatar
JJJ
JJJ is an unknown quantity at this point
TEAR OUT YOUR BACK SEAT'S AND CARPETING, IT SLOWS YOU DOWN.
Old Dec 5, 2002
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Quote
[hr]Originally posted by: JJJ
TEAR OUT YOUR BACK SEAT'S AND CARPETING, IT SLOWS YOU DOWN.[hr]
Don't forget to take out the spare tire as well.
Replace your intake...most noticeable gain.
Old Dec 5, 2002
rackness's Avatar
rackness is an unknown quantity at this point
NAWWWWWWWWWWWWWWZZZZZZZZZZZZ some tezzas and a monstrous aluminum wing oh and steelies in the front rims in the back
Old Dec 5, 2002
whitey's Avatar
whitey is an unknown quantity at this point
uummm..
trade your civic in for a much different car
if you wre really looking for any type of performance the civic should have been near the bottom of the list...
Old Dec 5, 2002
RyzRocket02's Avatar
RyzRocket02 is an unknown quantity at this point
Stickers, bro. You need stickers.
Old Dec 5, 2002
fraga's Avatar
Wicked Moderatuh
1. Go to local Fireworks stand
2. Buy lots of Bottle Rockets
3. Tape to side of car
4. Enjoy
Old Dec 5, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
ALL FREE!!!!! FIND OUT HERE!!!!
Guaranteeed that your car will do the quarter mile below 15 minutes.
Old Dec 5, 2002
Voiceofid's Avatar
End Bringer
there is almost no way to increase power on a low budget. especially on a 7thgen
maybe get rid of the car and buy a older car for cheaper, and use the extra money to buy mods
Old Dec 5, 2002
Grey's Avatar
DIY King
Here's a serious response:
1. Knife edge your throttle plate.
- Basically allows for more air flow.
2. Countersink your throttle plate screws.
- Again, more air flow.
3. Make your intake ports larger.
- More air flow. The sensors will see this and your ECU will add more fuel to balance the mixture. More fuel and more air equals more power.
4. Get rid of unnecessary weight (find it, it's all over the car).
- There are certain plastic protrusions on the interior side of the body panels.
- There are certain plastic protrusions on the intake manifold. Shave them off!
- There are rough aluminum edges on the block. Smooth them out and take off the excess material.
- The underside of the back bumper can be modified (cut off).
- The black plastic underneath the front bumper can be cut off in certain places.
- The black grille on the front bumper can be cut out (which also cools your engine more).
- Take off your interior door panels. Take off the white lining temporarily. Take out these two pieces of metal that don't belong there. Then reassemble.
- Take out all bolts and shorten them to just the right length (or buy new shorter bolts).
- Trim down metal parts that are overengineered, or lighten them by drilling out holes in appropriate places (mechanical engineering background needed).
5. De-burr your head.
- Take off the head and de-burr it. Basically take out any aluminum that's left over from casting.
- Porting can be done at this time.
The above is all free if you have the right tools.
6. Make your own AEM-style CAI
- Read this: Making Your Own AEM-Style Cold Air Intake
- For the filter use K&N's X-Stream series air filter: XStream® Air Flow Assemblies, Filters, and Filter Tops
7. Run lower up front and higher pressure in back. This will help with launching. (34 in back, 26 in front; fairly reasonable)
- You'll go through tires faster though, which is why it isn't free.
8. Get this if your car doesn't have it: oem part?
- Prevents wheel hop when launching, so you get more traction from the start.
9. Get Denso Iridium Spark Plugs (IK20's).
- Only spark plugs that actually do something, plus at less than $50 why not...
10. Get a shift light. Not a monster tach, just a shift light.
- Set it to blip at 6,800rpm. Shift when you see it blip. You'll probably shift at 7,000 (rev limiter) that way.
There, I said some stuff. Now use your noggin' and search this entire site for more of the above. It's out there, just go out and find it.
Old Dec 5, 2002
jwsisme's Avatar
jwsisme is an unknown quantity at this point
Get a Rear Wing, the bigger they are the faster you will go.
The stock Honda wing is too small.
Go Big!
Old Dec 5, 2002
JJJ's Avatar
JJJ
Before i seriously get involved with modding my engine I am seriously considering an engine swap, costly but may have more noticeable gains. I'm just getting it all tricked out before I get it fast. ONE DAY!
Old Dec 5, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Grey you da man ......
Old Dec 5, 2002
MadWheel's Avatar
Premium Boosted Member
Just installed my Mozart exhaust today, slightly noticable gain, nothing crazy but a great sound. my k&N fipk is being installed christmas vacation so my power should start adding there...like grey said...it's about air flow, do whatever you can to get more air into the engine, this is how honda made them economy cars. try to install the apexi s-afc so you can dump more fuel in to make up for the added airflow, those should be fairly noticable
Old Dec 6, 2002
Bartkat's Avatar
Grey,
"1. Knife edge your throttle plate.
- Again, more air flow."
Is there a DIY on these items?
thanks
Old Dec 6, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: Bartkat
Grey,
thanks[hr]
I'm working on it. Here are some threads about it:
Throttle Plate Edging
Throttle Plate Edging DONE!
Service Manual: Idle Speed
All of these threads are related to one another. Make sure you read the last one. I'm still working on the DIY, so the pictures in that one directory I posted may change. Actually, they already have a couple of times. Might change again. Jumpering the A&B pins on our service port doesn't do what I though it would. We're missing one pin, so we can't read the diagnostics by maintenence light blinks like earlier generations. I tried grounding it (since that missing pin is just the ground), but no go. I tried other combinations and no go. Anyway, all that's left is to adjust the idle. At WOT it screems more than before. I feel it when going from 60mph to 100mph in the 5,000 - 7,000 rpm range. I can accelerate much faster now at WOT in lower gears at higher rpm's than I could previously. Not sure how much faster, but at least I can feel it.
Old Dec 6, 2002
Bartkat's Avatar
Quote
[hr]Originally posted by: ak
Guaranteeed that your car will do the quarter mile below 15 minutes.[hr]
This is great. Sounds like something I would do.
Old Dec 6, 2002
Bartkat's Avatar
Grey,
Thanks. I'll read up.
After looking at those pics, I think I'll look into buying a used throttle body and work on it. That's how I did my struts and Konis. Got a set of struts from an almost new wrecked Civic for $125 and then did the mods, so I still have a set of OE struts. If I find one, I'll post the cost.
Old Dec 6, 2002
Grey's Avatar
DIY King
Yeah, that's what I would have done if I had the money.
Old Dec 6, 2002
Bartkat's Avatar
Check out item three on this link under "engine".
Honda Trouble Shooting
Old Dec 6, 2002
Grey's Avatar
DIY King
Yeah, I know what the problem is now. It's not that it's bad. it's that I did something to it to prevent it from functioning properly. That little plug I inserted only locks the idle at one rpm. I need a different plug. I'm thinking about how to make one now (an adjustable one). I'll post the DIY when I'm done.
Old Dec 6, 2002
IonRays's Avatar
IonRays is an unknown quantity at this point
push it off a cliff..I predict low 6's @ 200mhp depends how the aerodynamics of your civic is..If you had bottom diffusers and the arospeed vader wings. also a super kool bodykit it will fool gravity and break the sound barrier.. Enough velocity and air pushing from the bottom voooooom your flying maan.. Then no one will ask anymore "where are the flying cars in the year 2000" Honda tuners will have suprassed the next generation of technological wonders skipping a century! Amazing I say!
Ask Kurt Angle, he said "ohh its ture, its true"
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
crazydragon
Nov 7, 2001 05:13 PM
01civicboi
Bolt-on Engine Performance
Nov 2, 2001 07:33 AM
WSRcivic
Detailing
Nov 1, 2001 11:10 AM
ernhole1
Aug 2, 2001 11:12 PM
