New Gold Lines now available
The newly designed Gold Line spring kits for the 01> Civic are now available. They can be purchased at www.tornactive.com. The new design features a slightly different drop w/even fender well gaps front to back. Spring rates have remained unchanged.
Regards,
Gold Line Coil Springs
edited by VNlilMAN: made sticky
Regards,
The Standard One
i've heard the rear on the new coupe springs are slightly higher then the sedan springs.. is this true?
also if someone got a set of these can you post pictures and give us feedback. would like to compare it to the old ones and even the sedan ones...
The newly designed rear (coupe) spring is "not" taller than the sedan rear spring. There is still a fairly significant difference between the two. The sedan is significantly heavier in the rear. As soon as we have pics of vehicles w/the new kit we will put them up on the web.
Regards,
Jeff
Regards,
Jeff
Quote
[hr]Originally posted by: GoldLine
Regards,
Jeff[hr]
Regards,
Jeff[hr]
I'll post pics when the redesigned kit will be on my car
Gold Line customer service is greaaaat!! I'm proud of buying some gold line products...I recommend those products to everyone...especially to 7th gen civic owners!!!!!
Eric
Eric
Yay. I just picked up my New Goldlines Yesterday. I talked to Jeff and George down at Goldline. Thanks for all your help.
George personally sent my springs to a local Honda Dealer with my name on the box.
Im about to put the new springs on. (hopefully by tommorow).
Mad Props to Goldline and their customer service.
Thanks George and Jeff.
P.S. Ill post pics as soon as I get them installed
The Standard One
2dr will fit 4dr and 4dr will fit 2dr but ya its just the drop on the rear... sedans are heavier in the rear so of course the rear is going to sit lower then the coupe when comparing with the same springs
How "off" are the gaps with the old springs, it looks like the rear has no gap and the front has a finger's worth.
So there's going to be no difference besides even gaps?
Is it going to be a finger's gap all the way around or what?
I have the old version of the goldlines, they have the best drop I've seen so far.
BTW..maybe I'm dumb but I don't understand the difference between old and new-my gaps look the same....
jammer48
Oct 4, 2018 10:04 PM
powman02
Sep 15, 2015 07:38 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
