New Gold Lines now available
Old Dec 3, 2002
GoldLine's Avatar
GoldLine is an unknown quantity at this point
The newly designed Gold Line spring kits for the 01> Civic are now available. They can be purchased at www.tornactive.com. The new design features a slightly different drop w/even fender well gaps front to back. Spring rates have remained unchanged.
Regards,
Gold Line Coil Springs
edited by VNlilMAN: made sticky
Old Dec 3, 2002
FALKEN's Avatar
Civicforums Junkie
What's the drop?? And how much with shipping to Phoenix?? (01 EX Sedan)
Old Dec 3, 2002
GoldLine's Avatar
Overall drop height is still in the 1.75" range. Cost & shipping would be determined at tornactive.com.
Regards,
Gold Line
Old Dec 3, 2002
VNlilMAN's Avatar
The Standard One
i've heard the rear on the new coupe springs are slightly higher then the sedan springs.. is this true?
also if someone got a set of these can you post pictures and give us feedback. would like to compare it to the old ones and even the sedan ones...
Old Dec 3, 2002
Roy's Avatar
Roy
Roy is an unknown quantity at this point
hey, what is the spring rate on the goldlines?
Old Dec 3, 2002
VNlilMAN's Avatar
The Standard One
i think it was something like 290 lbs
Old Dec 3, 2002
GoldLine's Avatar
The newly designed rear (coupe) spring is "not" taller than the sedan rear spring. There is still a fairly significant difference between the two. The sedan is significantly heavier in the rear. As soon as we have pics of vehicles w/the new kit we will put them up on the web.
Regards,
Jeff
Old Dec 3, 2002
GoldLine's Avatar
175 LBS FRONT / 290 LBS REAR
Old Dec 4, 2002
TopFuel's Avatar
Ultimate OG Member
TopFuel will become famous soon enough
great......gold line changed their springs....
Old Dec 4, 2002
andyman97's Avatar
Turbo Guru
Quote
[hr]Originally posted by: GoldLine
Regards,
Jeff[hr]
Right, but isn't it true that with the new coupe springs on the coupe, it will sit approximately 1/4 inch higher than the sedan springs on the coupe and the old coupe springs sat about a 1/4 inch lower than the sedan springs?
Old Dec 5, 2002
Rider's Avatar
Rider is an unknown quantity at this point
I'll post pics when the redesigned kit will be on my car
Gold Line customer service is greaaaat!! I'm proud of buying some gold line products...I recommend those products to everyone...especially to 7th gen civic owners!!!!!
Eric
Old Dec 5, 2002
JOO's Avatar
JOO
JOO is an unknown quantity at this point
Yay. I just picked up my New Goldlines Yesterday. I talked to Jeff and George down at Goldline. Thanks for all your help.
George personally sent my springs to a local Honda Dealer with my name on the box.
Im about to put the new springs on. (hopefully by tommorow).
Mad Props to Goldline and their customer service.
Thanks George and Jeff.
P.S. Ill post pics as soon as I get them installed
Old Dec 5, 2002
Rider's Avatar
Yeahhh Is ther anyone here that can tell us something bad about gold line products? [IMG]i/expressions/face-icon-small-smile.gif[/IMG] I don't think so....
to Jeff!!!!!
Eric
Old Dec 5, 2002
jwsisme's Avatar
jwsisme is an unknown quantity at this point
This pic is from goldlines website, anyone know what springs are on this, the old or the new?
Does anyone know the tire size on this car?
Yes Sir, I like it!
Old Dec 6, 2002
GoldLine's Avatar
This vehicle has the "old" style kit installed.
Old Dec 6, 2002
CivicSouldjaEX's Avatar
so then what IS the dirfference between 2dr and 4dr springs? will 2dr fit on 4dr? if so, will it give a different drop?
Old Dec 6, 2002
VNlilMAN's Avatar
The Standard One
2dr will fit 4dr and 4dr will fit 2dr but ya its just the drop on the rear... sedans are heavier in the rear so of course the rear is going to sit lower then the coupe when comparing with the same springs
Old Dec 7, 2002
jwsisme's Avatar
How "off" are the gaps with the old springs, it looks like the rear has no gap and the front has a finger's worth.
So there's going to be no difference besides even gaps?
Is it going to be a finger's gap all the way around or what?
Old Dec 7, 2002
speedracersong's Avatar
worth buying?
better then ebachi (sp?) or neuspeed? just to name a few...
Old Dec 7, 2002
maverickja17's Avatar
maverickja17 is an unknown quantity at this point
I have the old version of the goldlines, they have the best drop I've seen so far.
BTW..maybe I'm dumb but I don't understand the difference between old and new-my gaps look the same....
jammer48
Oct 4, 2018 10:04 PM
powman02
Sep 15, 2015 07:38 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
