HP 4-1 Header w/ OEM Header Heat Shield
Old Dec 2, 2002
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
I would like to know will the OEM header heat shield (oem header cover) will fit over the HP Header. Since the HP 4-1 Header is illegal, i would like to mount the header cover onto the header to decieve the police officers.
Old Dec 2, 2002
Mbow's Avatar
The hp header is going to be way to big to fit under the oe shield. Plus, I am almost certain it lacks the hole for the bolt at the bottom of the shield.
Old Dec 2, 2002
cvc2k2's Avatar
just 2 bolts is enough. i just want it covered.
the 3rd one can be left off.
Old Dec 2, 2002
Mbow's Avatar
Quote
[hr]Originally posted by: cvc2k2
the 3rd one can be left off.[hr]
It will probably rattle and drive you nuts with just 2 but it might fit that way. The hp header is about 2x the size of the oe so I still don't think it would fit. I don't have the hp and haven't heard of anyone doing what you describe but have seen the header on someones car. So, take it for what it's worth.
Old Dec 2, 2002
IllusiveImports's Avatar
IllusiveImports is an unknown quantity at this point
first thing it isn't illegal the cat on it is. just use the hp with a stock cat. the cat on the hp header is basically a test pipe(pipe instead of cat= more hp)
Old Dec 3, 2002
cvc2k2's Avatar
yes it is illegal.. if you search. the HP 4-1 header is designed for off-road use only. i want to use the whole setup HP Header setup but have it concieled.
Old Dec 3, 2002
HondaLuver's Avatar
Its a celebration bitches!
NO
it will not fit
Old Dec 3, 2002
cvc2k2's Avatar
cool thanks.
Old Dec 3, 2002
CapYoda's Avatar
Escaped Convict
although it isn't what u were going for...
u should consider header wraps... they work like heatshields....
keeps the heat within the pipes so exhaust fumes exit faster and smoother.. and keeps the heat outta the engine bay.
Old Dec 3, 2002
Quote
yes it is illegal.. if you search. the HP 4-1 header is designed for off-road use only. i want to use the whole setup HP Header setup but have it concieled.[hr]
ok if you even read my thing you wouldn't feel so dumb. the header!!!! alone is perfeclty card approved and legal to use but the cat!!! thats with it makes illegal cause its really a test pipe with a bit of himney comb in it so they call it a high flow cat. but apparently you haven't looked on the forum or you woulda already known this.
Old Dec 3, 2002
cvc2k2's Avatar
i didnt read your post carefully. i would rather use the whole HP 4-1 Header setup.. or none at all.
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
