Need help finding a wire
Turbo Member
Does anyone know what wire on pre-cat o2 sensor is the signal wire? Im hooking up a air/fuel meter so that i can fine tune my V-AFC to get more power then I can share the program w/ everyone.
don't you need to tap the signal wire on o2 sensor on the intake b/c its before the engine. the fuel needs to be adjusted according to air going into the engine not the air coming out (from the header).
Turbo Member
This isnt for my V-AFC this is for my air/fuel gauge...you dont even use the sensor on the intake for the v-afc anyways, I just need know wich wire on the o2 sensor wire is the signal wire.
Quote
[hr]Originally posted by: Desi
don't you need to tap the signal wire on o2 sensor on the intake b/c its before the engine. the fuel needs to be adjusted according to air going into the engine not the air coming out (from the header).[hr]
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
MamaBear2015
May 3, 2015 02:17 PM
