HELP!!! AIR/FUEL gauge Question!?!?
Old Nov 11, 2002
stackz's Avatar
stackz is an unknown quantity at this point
I finished installing my autometer pro-comp ulta light air/fuel ratio gauge today and can't tell if it's working right or not...It sorta swings around somewhat most of the time. Like when I get on it, it does go towards the rich area but every now and then shifts back to lean quickly. When I let off the gas it goes to lean then disappears, then comes back to rich (I'm assuming this is correct since of course after letting off the gas there's going to be more air than fuel until it goes back to idle).
It just looks soo weird the way it oscillates around is all, is this normal??
-stackz[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 11, 2002
Atlantis's Avatar
Atlantis is an unknown quantity at this point
Sounds like you have everything working 100% correct. The reason it goes to lean and then disappears when you completely let off the gas is all of our honda's when the throttle is completely closed and the engine is over 800 RPM, the ecu shuts off all injectors so the engine gets 0 fuel under decel. This increases fuel mileage but its so lean b/c there is no fuel its off the range of the gauge. It swings wildly b/c the ecu is again changing the amt of fuel something like 4 times a sec for the best mixture.
Old Nov 11, 2002
stackz's Avatar
oh ok cool, I forgot completely about the ecu's little part to play in the whole deal and that makes a lot of sense. thanks man.
-stackz
Old Nov 11, 2002
pothole's Avatar
pothole is an unknown quantity at this point
That's the way mine works. So yours is working just fine.
Pablo
knknif
Aug 4, 2015 06:11 PM
DerbyDad03
Jul 27, 2015 11:34 AM
Kyles24
Jul 16, 2015 10:14 PM
NoobyKid
Jul 13, 2015 07:53 AM
Kyles24
Jul 12, 2015 09:15 PM
