Turbo Kit Parts List
Retired - SoCal FI Mod
I just want to know the essential parts to get a turbo kit assembled...
1. turbo
2. custom piping
3. intercooler
4. bov
5. new clutch
6. boost gauge
7. boost controller
8. a/f gauge
9. wastegate
10. new injectors
11. turbo timer
12. spark plugs
13. air filter
anyone like to add to this list or correct me on this list about the nonesstial parts that go with a turbo kit...
1. turbo
2. custom piping
3. intercooler
4. bov
5. new clutch
6. boost gauge
7. boost controller
8. a/f gauge
9. wastegate
10. new injectors
11. turbo timer
12. spark plugs
13. air filter
One of few in the 13's
This is a full kit:
Intake pipe
Turbo to piping hose
Throttle body to pipe
Hose clamps/Connectors
Hose clamps/Air filter
Ducting/Air filter
Connector/Air filter
Air filter
Boost gauge
Turbo & Drain gaskets
Wastegate
Steel downpipe
Header
Header/Turbo bolts
Downpipe/Turbo bolts
Wastegate/Flange bolts
Discharge tube
Turbo oil drain flange
BlowOff Valve
Fuel Pressure regulator
Brass T oil sending unit
Oil Sending Nipple
Steel oil line
Turbo oil inlet
Steel oil return line
Oil return to pan
Instruction sheet
Thermal wrap
Plastic vacuum fitting
Vacuum hose
Vacuum T fitting
Intake pipe
Ducting/Air filter
Air filter
Boost gauge
Wastegate
Steel downpipe
Header
Header/Turbo bolts
Discharge tube
BlowOff Valve
Oil Sending Nipple
Steel oil line
Turbo oil inlet
Oil return to pan
Instruction sheet
Thermal wrap
Vacuum hose
Vacuum T fitting
Turbos, Engines, Chassis and Suspension Tech
a turbo timer is nice...BUT NOT NEEDED. all it does is keep the car running for a couple minutes after you drive around in order to circulate oil through the turbo and cool it down.
Quote
[hr]Originally posted by: 4drcivic2k1
a turbo timer is nice...BUT NOT NEEDED. all it does is keep the car running for a couple minutes after you drive around in order to circulate oil through the turbo and cool it down.[hr]
at least that's what i've been told by others on this site.
Supramk3
May 11, 2015 07:55 PM
cloudguy
Apr 28, 2015 05:02 AM
