Does the 2003 guage cluster work with 2k1/2k2's?
Old Nov 5, 2002
DC5@EM2's Avatar
DC5@EM2 is an unknown quantity at this point
Im thinking about getting one cuz I accidently messed mine up(long story). Anyways, does the 2003 gauge cluster use the same plugins as the 2k1/2k2's? Does anyone know?
Old Nov 6, 2002
HomerSimpson's Avatar
All I can tell you is that I have a 2001 LX Coupe auto and a 2003 will not work. Same plugs different calibration. Best bet is to call your dealer if they are not a$$e$ otherwise IM me and I will get a hold of a friend at the dealer I go to.
Old Nov 6, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
related question:
Where is the mileage and trip odometer miles 'stored'. Is it in the ECU? So if we say... put a coupe gauge cluster in my sedan, the miles will still read correctly?
Old Nov 6, 2002
GhettoCivic's Avatar
GhettoCivic is an unknown quantity at this point
- I don't know from personal experience, but word on the street is that no, the mileage is stored IN the gauge cluster. When you swap clusters, it resets your mileage to 0 (with a new cluster) or whatever the previous owner had (a used cluster) Don't be dishonest...
Old Nov 6, 2002
SleeperCivic's Avatar
SleeperCivic is an unknown quantity at this point
Hmm, I would've guessed that the mileage is stored in the ECU. I dunno why they would split up computer functions like that. The ECU needs that when it trips the maintenence required light. I'm not 100% sure either , but that would be the most logical way...
About the gauge cluster - call Honda or look up the parts on that Honda website with all the diagrams (link please? I forget...) Again, my feeling is why would they change up the plugs? More costly and I don't think there is more function to the gauge pod. I think you could probably do this. It isn't a different shape overall is it?
Old Nov 7, 2002
liquidblue's Avatar
liquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trustedliquidblue should not be trusted
Quote
[hr]Originally posted by: GhettoCivic
- I don't know from personal experience, but word on the street is that no, the mileage is stored IN the gauge cluster. When you swap clusters, it resets your mileage to 0 (with a new cluster) or whatever the previous owner had (a used cluster) Don't be dishonest... [hr]
ghetto is right, the mileage is stored in the cluster. my car had it's gauge cluster replaced, and now i have this sticker in my door jam that says it was swapped at 11,880 miles and you need to add that to the odometer read to get an actual milage count. but if i remove the sticker, nobody knows any better because as far as i know, they don't put a VIN tag on the gauge cluster.
anyways, i would like to get some 03 gauges, i'll ask when i call them tomorrow and i'll let you know what they say.
Old Nov 1, 2003
pecX's Avatar
pecX is an unknown quantity at this point
pic
here what it's like the connector. I do searching too. But dont have the answer yet .
Old Nov 2, 2003
XxSoVeReiGNxX's Avatar
*READ ME*
This thread is one year old.
Just to clear up any confusion, gauge cluster swaps have been done for 2001 and 2002 models. I myself have swapped a 2002 EX cluster replacing the 2001 DX cluster in my car.
Mileage is stored both in the cluster and in the car's ECU. Therefore, if you swap a different cluster into your car, that cluster will show its own mileage and NOT your own car's mileage. This does not mean the mileage in your car's ECU will change to the mileage of the cluster you swapped in, the ECU will still count from original the miles that are on your car.
I strongly believe that 2003&up gauge clusters are NOT interchangeable with 2001 and 2002 gauge clusters. I haven't read of anyone trying it so far, and someone has yet to prove this.
Old Nov 2, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
all i know is honda doesnt usually make clusters easily swapable....i say easily because it can be done with rewiring ive seen a 2000 ITR cluster in a 90 hatchback and all he did was rewire the harness and plug in the itr cluster...u have to be very good with wiring and know what goes where on both car if u try this and know what ur doin itll work u could even get a type s or type r cluster if u know what ur doin but good luck if i had the cluster and i had a 01 or 02 id try it its not rocket science but ull need the manual for both years
Old Nov 2, 2003
Mags's Avatar
will you make out with me
Mags is an unknown quantity at this point
I heard that it can be done. i probably heard wrong though, cause I don't believe him.
Old Nov 2, 2003
like i said it can be done with some effort
Old Nov 2, 2003
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
The cluster will only work if you re-wire the plugs. I have the original honda service manual in front of me. The 2 clusters all use the same wires, but in different pins. They cannot simply plug in. But with the manual, it's real easy to swap the wires around to make it work.
Old Nov 2, 2003
Bellz's Avatar
Somebody needs to do a rewiring DIY to lay this topic to rest.
Any Volunteers?
Old Nov 2, 2003
skipbarber's Avatar
it has been done. its not hard to do...if you find smashed 03, take the cluster and plugs. then you need to get the helms electrical manual for both 2001-02 and 2003 and match the pinouts. i posted a FAQ in tech if you search for it, the milage for the car is stored in the ECM and the cluster. the cluster miles CAN be modified by any speedo shop. search and learn.
Old Nov 3, 2003
dru106's Avatar
ThE CoRRupToR
Damn!! I want those 03 guages!!!
Old Jul 30, 2005
ski7475's Avatar
ski7475 is an unknown quantity at this point
I have put an 01 ex cluster in 04 vp.Plug it in and go. the only prob is the abs light stays on because the vp doesnt have abs. I have since put in a 03 ex cluster and I had to re-pin the connectors. no big deal
Old Jul 30, 2005
mkymonkey's Avatar
I haven't been here in a long time
mkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the rough
old thread 2-3 years....wow
Old Jul 30, 2005
Caucasian.Asian's Avatar
n00b alert! ahaha bringing back a 2 year old thread.
Old Jul 30, 2005
cj2185's Avatar
cj2185 is an unknown quantity at this point
Is there an easier way to do this conversion rather than pulling all the wires out. Relocating it b/c it a b**** to take the wires and puting them back on.
Old Jul 30, 2005
no, and it only takes 20min to take them out and re-pin them.
i did it to my friends car at night in a parking lot. lol the whole thing, from start to finish, only took 30 min.
Old Jul 30, 2005
R1Style's Avatar
The clusters from a 03+ will work on a 01-02. There's a DIY on this site on how to rewire the pins. I've personally done the conversion on 2 Civic's (Big's and APRboy's).
Old Jul 31, 2005
cj2185's Avatar
does any live near chicago, so they can do it for me. ill pay em.
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
trellex
May 24, 2015 04:39 PM
ORskier
May 3, 2015 12:54 PM
Bigdaddy198
Apr 30, 2015 08:36 PM
