Air/Fuel Ratio Gauge Install help PLZ
I just got an Pro-comp ultra-lite air/fuel ratio gauge today and was reading the instructions....My 98 ex's oxygen sensor is apparently a heated one since it's got 4 wires (a green, a white, and two black wires)?? My question is does anyone know which one of these wires is the signal wire?? If not can someone point me to an online source that shows the wiring diagrams for my car?? thanks...
-stackz[IMG]i/expressions/beer_yum.gif[/IMG]
That doesn't help me at all...I've got the factory instructions but I need to know which wire on the oxygen sensor itself is the signal wire to the ecu and which one is the signal wire for the sensor heater....
-stackz
-stackz
Turbos, Engines, Chassis and Suspension Tech
hmm i bet your dealer could tell you...or a shop in your town...although im pretty sure its the green one...black is ground and the white is positive so...dont quote me on that though
I figured I might have to travel to the dealer for the answer but was hoping I could find someone on here that's installed an air/fuel ratio gauge themselves with a 4 wire oxygen sensor [IMG]i/expressions/face-icon-small-tongue.gif[/IMG] Oh well, thanks for the responses man, appreciated.
-stackz
-stackz
its the white wire
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] muffler 006.jpg (30 Kb)
would it matter (or burn something up) if I turned on the car and hooked the gauge to the battery then tested it in the white and then the green wire to see if it responded?? Just kinda curious before I go make a booboo or something.
-stackz
-stackz
juror
May 26, 2015 06:35 PM
