Sneaky Pete (nitrous system)*opinions*
Old Oct 27, 2002
HCCriminal's Avatar
an0therpin0y
Quote
[hr]The Sneeky Pete was designed as a true "Cheater Kit." This kit will enable you to obtain that extra tenth of a second without being obvious. It will be necessary to jet the carburetors a little richer (over and above what is normal, since you will have to compensate for the nitrous from the Sneeky Pete) while being "sneeky" since no additional fuel source is utilized. The kit comes complete with a compact, easy to conceal 10oz. bottle, nitrous solenoid, nylon nitrous line, wiring, 9v battery holder and an assortment of jets. Carry it in a briefcase! [hr]
Totally portable system installs in minutes. Uses two 9volt batteries for power. The ultimate trick!
Any opinions about it ? a little nitrous shouldn't hurt the engine right ?
Old Oct 27, 2002
Nuts's Avatar
Nuts is an unknown quantity at this point
hmmmmm, VERY interesting
Old Oct 27, 2002
vietstylez's Avatar
dang...the big bottle is so much kooler though....
Old Oct 27, 2002
civichx81's Avatar
civichx81 is an unknown quantity at this point
i had the bottle a while back, but i sold it on ebay. it is cool to have if you wanna race someone and you dont want them to see u have nos. like for me, all my buds know i squeeze all the time and my friend has a 92 civic hatch and he told me not to squeeze. i told him i didnt have the bottle. it wasnt in the trunk and i had my sneeky pete bottle under my seat..heh so i used it and smoked him really bad. its fun to have but i like having my 10 pound bottle more.
Old Oct 27, 2002
nucks's Avatar
nucks is an unknown quantity at this point
i bet that bottle gets empty reallllly quick, maybe better just to get the bigger one just for conveinance reasons
Old Oct 27, 2002
HCCriminal's Avatar
an0therpin0y
all i need is a lil boost, i dont' need it all the time ..!! only use it once in awhile !!
Old Oct 27, 2002
XoULaBeAT's Avatar
XoULaBeAT is an unknown quantity at this point
how much is that thing? where do u install it?
Old Oct 27, 2002
sspem2's Avatar
em2
what shot is that. a 20 shot or something[IMG]i/expressions/laugh2.gif[/IMG]
Old Oct 27, 2002
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
better figure out a way to add extra fuel with that nitrous, running lean on nitrous is very bad
Old Oct 28, 2002
HCCriminal's Avatar
an0therpin0y
yeah i was just thinking about that ..!! hmmmm[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 28, 2002
SLeePeR012's Avatar
SLeePeR012 is an unknown quantity at this point
The Apexi VAFC would work rite? Cant you regulate on the air fuel mix and jus run a a lil lean, hopefully try it out firs tona dyno so nothing really bad happeneds on the road.
Old Oct 28, 2002
2001CIVICLX's Avatar
2001CIVICLX is an unknown quantity at this point
That is a tiny bottle. I wouldn't mind having that kind of shot, just for those particular times you need it. And if it's not full, OH WELL!!! I'll get em next time.
Old Oct 28, 2002
prototype's Avatar
x-factor
i was concidering that kit with a bigger bottle so i got more shots b4 i have to refill... but in a 1/4 mile it will tak of 1/10 of a second....so i dunno if its worth it... it shouldnt hurt you engine b/c of such little hp gain just make sure u got yer intake/header/exhaust installed....b/c if you dont it will blow b/c of too little air flow
Old Oct 28, 2002
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
Never ever run lean on nitrous. Did I say NEVER?
anyway, yes you could controller fuel delivery with a S-AFC, or adding larger injectors and controlling the injectors why not on juice. But why do that when you can just purchase a NX kit and have all the things you need without extra cost of having to buy something else? scared to run a 50 shot? they supply 35 shot jets as well.
Old Oct 29, 2002
SLeePeR012's Avatar
PlatCruiser, I think you forgot what this thread was about...
The Sneaky Pete, 35 shot 50 shot 75 shot, all sports the bottles.
Old Oct 29, 2002
I forgot what this thread was about? that with a dry nitrous system and no way to increase fuel, you'll burn up the motor? what does the bottles have to do with it other than size? you can get any kit with the size bottle you want
Old Nov 4, 2002
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
ur right but we're looking for that sneaky type of nos, not like obvious type of NOS. i'm pretty sure the sneaky pete wont burn nothing with such a small boost. i agree having exhaust, intake and header installed before using it.
Old Nov 4, 2002
Quote
[hr]i'm pretty sure the sneaky pete wont burn nothing with such a small boost. [hr]
ummmm detonate enough and you'll burn a hole in the piston....
Old Nov 4, 2002
u for real? but this so called "mini" nos is so tiny compare to the full nos kits. as long as we have the whole setup, intake, header, exhaust we should be right
Old Nov 4, 2002
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
If you are gonna squeeze you should squeeze!!!...don't give a little baby
pinch. Since that is what the sneaky pete is. that is about a 3 second spray wich will only take 1/10th off on a quarter mile. It is only used for drag and if you need a little pinch of power at the end of the 1/4 mile time to hit your dial in time.
NX epress makes the best kit for our cars. Besides you do not want to hit the nitrous at the wrong time and pop your engine. N2O works safest at wide open throttle.
Old Nov 5, 2002
hm...maybe i should look into a NX
Old Nov 5, 2002
and to be exact, how many shots is one of these tiny thingy? dont want to refill after every race
Old Nov 5, 2002
Quote
[hr]u for real? but this so called "mini" nos is so tiny compare to the full nos kits. as long as we have the whole setup, intake, header, exhaust we should be right [hr]
lemme say again the bottle makes no differene in the kit. Just becuase it is small does not make it better. The size of the jet, jets used determines the amount of nitrous entered into the motor.
intake, header and exhuast does not make nitrous any safer than a stock car. Understanding how to use the kit and all of its accesories is a start. Installing the kit correct, having the correct pressure, running enough octane, not too much ignition timing, using the correct plugs is just a start.
Old Nov 5, 2002
so basically ur saying the sneaky nos is running lean and its dangerous. i hear u, okay i just wanna know ur opinion, wats a good nos kit out there thats safe or safer from ur opinion. of course all the safety precaution u mentioned is a start, but i just want your opinion see which kit you think is better.
Old Nov 5, 2002
kjgracing's Avatar
Quote
[hr]Originally posted by: iluvbritney
and to be exact, how many shots is one of these tiny thingy? dont want to refill after every race[hr]
I would say its about a 20 shot since it only improve 1/4 time by 1/10 or so and 2-3mph overall
Sneaky pete cheater
Old Nov 5, 2002
kjgracing's Avatar
nirous kits
7th gen civics ECU is different than the previous models and a VENOM kit
will not work.
Read this Nitrous Express install on a 7th gen civic
All you questions should be answered by reading this
Old Nov 5, 2002
WeakVTEC's Avatar
WeakVTEC is an unknown quantity at this point
Any shot at ALL is going to cause damage to the engine if it does not have all the safety equipment set up. IMO if you are going to run nitrous just go for the big one with a 50 shot or more.
Old Nov 5, 2002
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
Unless you figure a way to add more fuel to the equation I strongly reccomend you not to use that kit... Nitrous requires fuel to make it work right.. If there isnt enough fuel then the motor goes lean. Then boom, catch parts in a bucket.. that product is intended to carburated cars where tuning that extra fuel i isnt a problem. At the very least a return fuel line is needed to increase fuel pressure. its NOT going to happen in your car, just get a regular kit.
Old Nov 6, 2002
Bartkat's Avatar
The ad says the kit is for cars with carbs. With them you can put bigger jets. We don't have carbs, so why are we even talking about it here?
coumadin01
Electronics
25
Jul 25, 2019 04:19 PM
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
