glasspack-resonator???
Old Oct 24, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i want to silence my exhaust a little bit so i can hear my intake. i was told to go buy a glasspack?? [IMG]i/expressions/face-icon-small-confused.gif[/IMG] wtf is this??? please help and give other suggestions if you can think of any.
INJEN
Old Oct 24, 2002
HomerSimpson's Avatar
A glasspack will not silence it, most likely make it louder. I had dual glasspacks on my '79 Monte Carlo and boy did it rumble.
This is a sound clip of a glasspack on a stock inline 6
Old Oct 24, 2002
injencivic's Avatar
ok then what should i get to silence the exhaust?
Old Oct 24, 2002
injencivic's Avatar
Quote
[hr]Originally posted by: HomerSimpson
This is a sound clip of a glasspack on a stock inline 6[hr]
i dont want that hehe. i want to hear my intake pretty much is all i am wanting. therefore i need to quiten the exhaust.
INJEN
Old Oct 24, 2002
mikalem's Avatar
mikalem is on a distinguished road
Do you have the stock exhaust or is it an aftermarket one?
Old Oct 24, 2002
injencivic's Avatar
aftermarket universal and the resonator was taken off. now i want to silence the exhaust so i can hear my injen cai.
Old Oct 24, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
put the resonator back on
Old Oct 24, 2002
injencivic's Avatar
I DONT HAVE A RESONATOR STILL.
Old Oct 24, 2002
Boosted2k2's Avatar
Quote
[hr]Originally posted by: injencivic
I DONT HAVE A RESONATOR STILL.[hr]
no, what i'm saying is... any muffler place will put a regular resonator on your car, they have them in stock.
Old Oct 24, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Homer probably does not have a muffler and only the glass pack res. he probably has straight pipes from the headers to the glass pack res and straight pipes to the exhaust tips. A resonator resonates(hence the name) the waves in a camber that muffles it(quiets) the noise from the combustion camber. A glass pack is better because the material inside the res(glass) does not expand like a metal res will. you will hear the glass pack res cool off(it makes this dripping/pinging sound). If the material in the res does not expand, you will not create any back more back pressure than provided by the res. I hope this helps(i do not know a lot about cars(i know a lot more because of having a civic, but not because I took automotive classes), I just know a lot about physics and a little about thermodynamics.
Old Oct 24, 2002
injencivic's Avatar
Quote
[hr]Originally posted by: Smokie2k2LX
Quote
no, what i'm saying is... any muffler place will put a regular resonator on your car, they have them in stock.[hr]
ahhh i see said the blind man!!! do you all know how much its gonna cost me for this?
Old Oct 24, 2002
Bellz's Avatar
I used a glasspack on my previous car, a Prelude. I had increased the pipe size, took off the resonator, and used a free-flow muffler. It was horrendously loud, so the muffler shop guy recommended a glasspack to act as a resonator. It worked great and sounded good, but not too loud. The only time you could hear the glasspack was at high revs. It made a kind of "brrrratt" sound. If you don't like it, you can always use a generic resonator.
Here's a couple links for you:
Summit Racing's Dynomax Glasspack
JC Whitney's Glasspacks
Old Oct 24, 2002
Dave's Avatar
Dave is an unknown quantity at this point
My glasspack did not make a "brrrrat" noise, if anything, it helped smooth out the note and lowered the noise a few notches.
Old Oct 24, 2002
Quote
[hr]Originally posted by: ASWZero
Homer probably does not have a muffler and only the glass pack res. he probably has straight pipes from the headers to the glass pack res and straight pipes to the exhaust tips. A resonator resonates(hence the name) the waves in a camber that muffles it(quiets) the noise from the combustion camber. A glass pack is better because the material inside the res(glass) does not expand like a metal res will. you will hear the glass pack res cool off(it makes this dripping/pinging sound). If the material in the res does not expand, you will not create any back more back pressure than provided by the res. I hope this helps(i do not know a lot about cars(i know a lot more because of having a civic, but not because I took automotive classes), I just know a lot about physics and a little about thermodynamics.[hr]
Yes I had a 350 V8 with 2.5" straight pipes off the headers right to the glasspacks and then out the rear. Gave the car a great rumble.
Old Oct 25, 2002
DMX's Avatar
DMX
DMX is an unknown quantity at this point
right now i have my resonator taken out and replaced with a straight pipe out with an n1 muffler.... i was just wondering if i replace the straight pipe with a glass pack how would it sound???
is using a glass pack as a resonator the same as using the stock resonator.... sound wise???
Old Oct 25, 2002
SMX's Avatar
SMX
SMX is on a distinguished road
A Glasspack should work fine as a resonator. It should quiet the note down and maintain a low end rubmble. Just make sure to get a free flowing pack. Cherry Bombs are about the worst on the market. Try and get one with smooth interior that will not affect exhaust flow. The types with the 3D cutouts will inhibit flow. Look through the center and see if the pipe is smooth with holes drilled (like the Borla straight throughs). That's what you want.
