... and also, anyone have a squeaky clutch pedal?
Old Oct 21, 2002
impetigo's Avatar
impetigo is an unknown quantity at this point
after about 2 months, my clutch pedal has started to squeak/creak when it's being released (after being pressed down completely). it's REALLY ANNOYING as you might imagine, hearing this loud SQUUEEAAAKKK!! every time you shift. i think it started b/c i had been pressing the clutch too hard to the floor for a couple weeks. but still, it seems kind of retarded. has anyone experienced this sort of thing and can it be fixed (with some grease or if it's not the pedal squeaking i might be stuck with it forever)?? thanks for any input.
Old Oct 21, 2002
WeakVTEC's Avatar
WeakVTEC is an unknown quantity at this point
Mine's done it since 1200 miles, I have 16000 on the car now and i CHANGED my clutch. It's probably something with the pedal/linkage, doesn't hurt anything, it's just annoying. Some lubrication somewhere should fix it but I have been too lazy to check it out
Old Oct 21, 2002
Mbow's Avatar
Yep, I had the same problem. I just sprayed some wd-40 on the parts that were making the noise. That was over a month ago and it hasn't come back.
Old Oct 21, 2002
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Yeah I had the squeaky clutch pedal before and it seemed to have go away on its own.....
Old Oct 21, 2002
impetigo's Avatar
Quote
[hr]Originally posted by: Mbow
Yep, I had the same problem. I just sprayed some wd-40 on the parts that were making the noise. That was over a month ago and it hasn't come back.[hr]
that sounds worth a try, not really sure which part exactly is making the noise. did you just kind of spray the pedal as far down as you could or did you actually take stuff apart? i tried moving my seat further back so i would put less pressure on the clutch, and that seems to have helped. only squeaks occasionally now, but i gotta get some WD40...
[IMG]i/expressions/face-icon-small-tongue.gif[/IMG][IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Oct 21, 2002
Mbow's Avatar
Quote
[hr]Originally posted by: impetigo
Quote
[IMG]i/expressions/face-icon-small-tongue.gif[/IMG][IMG]i/expressions/face-icon-small-tongue.gif[/IMG][hr]
get your head down underneath the clutch pedal...yea, it hurts to look under there...you will see a tube that comes off the rear of the pedal that goes into a little cylinder in the firewall...that tube has a piece on the end of it and it slides in and out of that tube....that's what was making my noise...I would have used some grease but didn't feel like hunting it down....
You'll understand what I am talking about when you look under there.
Old Oct 21, 2002
impetigo's Avatar
thanks alot, i am going to try that out soon for sure.
Old Oct 22, 2002
civicdude's Avatar
I have it too....Its kinda annoying....I just make the radio louder and the sound is gone lol
Old Oct 22, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
I have it off and on. When it's cold it does it, but if it's warm out, it's fine. I think it's just something in the pedal mounting, so I'm just gonna leave it.
Old Oct 22, 2002
DYCE's Avatar
DYCE is an unknown quantity at this point
I had that problem with my clutch ....just get down there and press the pedal with ur hand all the way in and put some wd 40 or something on it and let it up slowly while u do that that'll do the trick
Old Oct 23, 2002
Rider's Avatar
Rider is an unknown quantity at this point
Mouhahaahah
Had the same problem with my clutch pedal and was searching if anyone had the same problem =))))
I haven't hear it before my girl friend told me....what is this little sound ? ? ? [IMG]i/expressions/face-icon-small-smile.gif[/IMG] mouhahaah the clutch pedal that is making some noise....
I've put some WD-40 and the problem is solved!
Eric
Old Oct 24, 2002
WeakVTEC's Avatar
Are you just spraying the wd40 up where the pedal connects under the dash?
Old Oct 24, 2002
DYCE's Avatar
Yeah just spray up in that little spot that the pedal comes out of and work the pedal as you do it cause some spots are not as exposed as to when u press the pedal all the way
JetsterDajet
Aug 15, 2015 08:07 AM
alaga
25
Aug 13, 2015 04:42 PM
