2003 Civic Fuel System
Old Oct 14, 2002
Red2k3Civic's Avatar
Red2k3Civic is an unknown quantity at this point
My Window Sticker on the 2003 Said:
1.7 L VTEC Engine
127 HP
Flow Back Fuel System
Now, I'm lazy and I have not looked, but doesn't this suggest to you that they have done away with the returnless fuel system??
Eric
Old Oct 14, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
umm...im goin to the dealer tonight [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 14, 2002
Ichiban's Avatar
Ichiban is an unknown quantity at this point
I highly doubt it. When I got my car it says it came with the VTEC-E and not regular SOHC VTEC. The only differences between the years would be cosmetic. All the mechanical parts and systems would be the same
Old Oct 14, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
My 02 EX sticker says that too... But I'm not sure what it means....
Old Oct 14, 2002
mikalem's Avatar
mikalem is on a distinguished road
VTEC-E is the type of engine in our cars.......
Old Oct 14, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
every post says add-ons don't do much for out car because or the ULEV crap and the returnless fuel system. Can anybody tell me why the returnless fuel system affects performance? I've read a lot about it on the internet and all I can come up with is that it is just costly to maintain. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 14, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: Smokie2k2LX
every post says add-ons don't do much for out car because or the ULEV crap and the returnless fuel system. Can anybody tell me why the returnless fuel system affects performance? I've read a lot about it on the internet and all I can come up with is that it is just costly to maintain. [IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
The returnless system doesn't affect anything if you stay naturally aspirated..if you forced induction it does not allow for proper fuel regulation and pressure.
Old Oct 14, 2002
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
Quote
[hr]Originally posted by: mohawkboom
Quote
The returnless system doesn't affect anything if you stay naturally aspirated..if you forced induction it does not allow for proper fuel regulation and pressure.[hr]
Where is the valve that only allows uni-directional flow?(assuming it's a valve) if not is there any way to modify they system to allow back flow?
Old Oct 15, 2002
Ichiban's Avatar
It's not a valve. It's missing the whole return line. Acually there is a return line, its in the gas tank. The 6th gen had everything in the engine while we have everything right by the gas tank (fuel regulator, fuel pump...etc).
In order to have the return line in the engine you would need to move all that stuff in to the engine bay. I think it can be done its just that nobody that I know of has done it. Thats what I plan to do so that I can turbo my car. Even If I get a swap I would get the return line.
The EXs don't have the VTEC-E they have the regular SOHC VTEC. The HX has the VTEC-E.
Old Oct 15, 2002
Steggy's Avatar
Steggy is an unknown quantity at this point
Look at the Turbocharged RSX in the new(11/02) Import Tuner on page 36. Dynamic Autosports modified the fuel system to support boost."A polished collector tank sitting in the trunk area feeds the fuel system through the trunk-mounted SX 1200-hp fuel pump to ensure adequate fuel is supplied to the car even under the most rigorous driving conditions. Additional fuel hardware comes in the form of the 440RC injectors and the Walbro in-tank fuel pump."
I called DA, and whoever picked up the phone didn't know too much. he said he didn't know exactly what went into the fuel system, but the article did a pretty good job explaining it. I was like whatever and thanked him for his time and hung up. We have some damn good shops in MD and VA so they should be able to replicate this setup. BTW the HKS F-Con S piggyback engine management sytem tunes the A/F ratio.
I'll be attempting to do this before I get too serious about getting a turbo kit.
Old Oct 15, 2002
artychris's Avatar
artychris is an unknown quantity at this point
I went through and read an older Car and Driver (Oct 01) in the Porche 911 Carrera article. Porche also utilizes a Returnless Fuel System for the benefit of cooler fuel. Cooler fuel reduces the risk of predetonation which in turn increases fuel efficiency.
A good analogy is a circle. At one end of the circle, there's a fuel tank and the line that goes from the fuel tank goes into the engine and any unused fuel will be promptly returned BACK to the fuel tank. That's how older gen Honda's can easily use a fuel pressure regulator for boosted applications to increase the vaccuum pressure for fuel to flow to engine. With a returnless fuel line any such modifications cannot be done mechanically but rather electronically via a stand alone or piggy bag computer.
Old Oct 16, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: Boilermaker1
My 02 EX sticker says that too... But I'm not sure what it means....[hr]
It says "flow back fuel system" as well? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
I need to check my 01's sticker too...
Old Oct 16, 2002
on the warm fuel thing...you can run the fuel through a fuel cooler before you hit the fuel rail...im not sure how much they cost, but i know they work well.
Old Oct 16, 2002
KocKDieselUMD's Avatar
KocKDieselUMD is an unknown quantity at this point
My '02 EX sticker says and I quote:
1.7 Lil 4 Cyl Engine
4-Spd Automatic Transmissiong
Multiport Fuel Injection
Feedback Fuel System
Old Oct 17, 2002
Jap-Euro Fusion
Quote
Quote
[hr]My '02 EX sticker says and I quote:
Feedback Fuel System [hr]
Bingo... mine says that, except for 5 speed.
Old Oct 17, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
My sticker says:
2001 Civic
1.7 liter 4-cyl engine
5-spd manual transmission
multiport fuel injection
feedback fuel system
Also, under "Technical Features" it says:
127hp 1.7 Liter SOHC 16 Valve
VTEC-E 4 Cylinder Engine
And mine final assembly point was East Liberty, OH.
Also my engine was made in the USA, while my transmission came from Japan.
Glad I saved the sticker. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 17, 2002
Grey's Avatar
DIY King
Mystery solved, it's not a return fuel system.
Old Feb 1, 2003
how gay, the tech told me they changed the fuel pressure regulator for the 2003...
Old Feb 2, 2003
dragoon's Avatar
2002 Civic
1.7 Liter 4-cyl engine
*shrug*
Old Feb 3, 2003
HondaLuver's Avatar
Its a celebration bitches!
im guessing the feedback part just says that the ecu regulates the fuel intake?
Poopies
Apr 20, 2017 11:36 PM
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
