installing an alarm......
Old Oct 9, 2002
JoeyP's Avatar
JoeyP is an unknown quantity at this point
I'm installing an Excalibur ATV1000 alarm, and I've been using http://www.2k1civic.com/diy/wiring.cfm and whatever else I can find on the web as a guide for the Civic's wiring since no manuals are out yet (except the dealer manual - too much $$).
Anyhow...
I can't find (or are confused with) the wires for the following:
Door lock & unlock (can't find it)
Parking lights (Can't find it)
Dome light (red/green I know, but there's 15 red/green wires under the dash and I've cut and soldered them all by now)....
If anyone knows what they're talking about and can take some pictures of the locations and of the wires themselves, I'd be much abliged, and it'd save me $100 from someone else doing it.
Thanks,
Joey
Old Oct 9, 2002
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
the door lock wires and the parking light wire and door triggers are all in the same area... the door locks are in a different plug ,
but they are all there if you cant find them , i suggest professional install...
YEAR: 2001 MAKE: Honda MODEL: Civic STYLE:
| ITEM | WIRE COLOR |POL | WIRE LOCATION |
| 12V |white | + |ignition harness |
| STARTER |black/white | + |ignition harness |
| IGNITION |black/yellow | + |ignition harness |
| ACCESSORY |black/red | + |ignition harness |
| SECOND ACCESSORY |white/red | + |ignition harness |
| POWER LOCK |white/blue | - |gray plug above drivers kick|
| POWER UNLOCK |white/green | - |gray plug above drivers kick|
| LOCK MOTOR |yellow/black | |back of the fusebox *3 |
| UNLOCK MOTOR |yellow/green | |back of the fusebox *3 |
| DISARM DEFEAT |yellow | |back of the fusebox *3 |
| PARKING LIGHTS + |red/black | |back of the fusebox |
| PARKING LIGHTS - |blue | |factory alarm plug *1 |
| HEADLIGHTS |blue/red | - |headlight switch |
| DOOR TRIGGER |*2 | - |factory alarm plug *1 |
| DOME SUPERVISION |comes on with unlock | | |
| TRUNK/HATCH PIN |red | - |factory alarm plug *1 |
| TACHOMETER |blue | |test connector *4 |
| SPEED SENSE |white/green | |PCM *5 |
| BRAKE WIRE |white/black | + |brake pedal switch |
| HORN TRIGGER |orange | - |steering column |
| WIPERS |blue (L), blu/yel(H) | - |steering column |
| LF WINDOW UP/DOWN |red/blk - red/yel | A |drivers window switch |
| RF WINDOW UP/DOWN |blu/red - blu/wht | A |drivers kick panel |
| LR WINDOW UP/DOWN |brn/wht - brown | A |drivers kick panel |
| RR WINDOW UP/DOWN |blu/org - brn/yel | A |drivers kick panel |
| RADIO 12V |white/red | + |radio |
| RADIO GROUND |black | - |radio |
| RADIO SWITCH |yellow/red | + |radio |
| RADIO ILLUMINATE |red/black | + |radio |
| POWER ANTENNA | | | |
| LF SPEAKER |grn/blk - lt green | |radio |
| RF SPEAKER |grn/yel - gry/red | |radio |
| LR SPEAKER |blu/wht - blu/blk | |radio |
| RR SPEAKER |pink - blu/yel | |radio |
NOTES:
NOTE: This vehicle has an immobilizer system that needs to be bypassed
when adding remote start. Use DEI part number 555U.
*1 The factory alarm plug is a green plug above the drivers kick panel.
*2 The drivers door trigger is green, front passenger door trigger is lt.
green/red, and the rear door trigger is green/white.
*3 In the top left plug.
*4 It is a 2 pin plug to the passenger side of the battery.
*5 The PCM is behind the glove box. The vss is in a connector A (31 pins),
pin 18. The vss is also blue/white at the cruise control module to the
left of the steering column.
(c) 1994-2002 Directed Electronics, Inc. All Rights Reserved
IMPORTANT: This wiring information is being provided free of charge on
an "AS IS" basis, without any representation or warranty. It is your
responsibility to verify any circuit before interfacing with it using
a digital multimeter. Directed Electronics, Inc. assumes no responsibility
with regards to the accuracy or currency of this information. Proper
installation in every case is and remains the responsibility of the
installer. DEI assumes no liability or responsibility resulting from an
improper installation, even in reliance upon
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
