good adhesive removers?
Alright i'm going to remove my eyelids because my car is going back to mostly stock. problem is, it came with very strong 2-sided black tape. what are some good ways to remove the tape. it's on the lens so i cant really scrape it with anything.
i've never used goo be gone before, but i usually use carb cleaner for adhesives i need to get off. give that a try, it SHOULDNT damgage ur lens hopefully and tell me if it worked.
good adhesive removers? DO NOT USE GOO GONE OR ANY OF THOSE THINGS!!!!!!!!! they will fuuuck up your lens!!!! i speak from experience. i was clearing my lights and some goo got on the inside lens, tried goo gone or goof off...one of those, and now i have a "frosted" lens. it looks bad... so dont do it. i dont know what to tell you to use tho...the lens is a bad thing to get anything on i suppose.
Goo Gone is okay if you are using it on the outside of the lens, but it will serious mess up your lens if you are using it on the outside of the lens...I use that stuff all the time to remove bugs and dirt from the outside of the lens...but it seems as if u are trying to remove sticky stuff on the outside of the lens, so it should be okay...
2Hottie
2Hottie
Quote
[hr]Originally posted by: Fern
yea, its on the actual outside of the lamp[hr]
2Hottie
i am speakin from experience as well,,use a heat gun / hair dryer to soften the adhesive,gently work it slow to peal it off,spray 3M adhesive remover on and let set for a bit,wipe off with soft terry cloth.
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
