DIY short shifter...
Old Sep 30, 2002
armageddon's Avatar
armageddon is an unknown quantity at this point
I tryed searching but came up with no results. How bad is it hack saw off your shifter to make yourself a short shifter. I dont really know how much it will help. Maybe if I got a shift adapter also. I am all about DIY stuff because I am one broke ****!!!
Old Sep 30, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
obviosuly cutting the shifter is going to lower the height of the shifter, but i am not sure if it actually would reduce the throws.....hummm, not sure [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Sep 30, 2002
armageddon's Avatar
Does any one know if it would shorten the throw??
Old Sep 30, 2002
robbclark1's Avatar
Retired suspension supermod.
If you just cut the bar for the shifter, then no. If you create a different point of attachment then yes. You can weld a piece to your stock shifter that mimics the role of a short shifter.
Old Sep 30, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: armageddon
Does any one know if it would shorten the throw??[hr]
Actually... YES! I had some illustrations that made this point. What happens is that the distance betwean the gears shortens when you shorten the length of the shifter. Imagine a very long shifter (let's say two feet high). You have to grip it at it's end and then shift with it. Imagine how far you'de have to move the shifter to get it from gear to gear... See!? A shorter shifter reduces the throw!
Anyway, if you want to DIY your shifter then get a shift **** like Razo and a threading tool. Cut the shifter and re-thread it. Then just screw the Razo **** on. I mention Razo because the stock shift **** won't fit. It won't fit because the hole in the stock shift **** will be too small for the new diameter of the shifter.
Old Sep 30, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
i had illistrations too....it WILL shorten the throw. The old revos where the exact same shifter just cut down about an inch.
Old Sep 30, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
if you shift well enough, the lever will actually suck itself into the gear you are aiming for. i have only done that once.
Old Sep 30, 2002
robbclark1's Avatar
I think i understand what you guys are saying, but it seems you are doing is shortening the amount you have to move your hand, not the gear points (like with a traditional short shifter). I may be understanding this wrong, but i understand what you are saying as just shortening the amout you have to move your hand, not changing actual shifter. Maybe someone can clear that up.
Rob
Old Sep 30, 2002
armageddon's Avatar
My basic goal is to shorten the throw. Or to put it bluntly not move my hand so much between gears. Also what was LikeWEEEEEE talking about sucking itself into gear. Did he mean with the DIY mod or an aftermarket SS kit.
Old Sep 30, 2002
Grey's Avatar
DIY King
Found the file I created a long time ago...
See? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] grey-SSthrow.gif (5 Kb)
Old Oct 1, 2002
armageddon's Avatar
grey your the man. thanks.
Old Oct 1, 2002
OsOBooSTeD's Avatar
OsOBaNNeD
hey i got the solo short shift adapter and I cut my shifter..... the solo reduced throw and the cutting off it just helpt hand movement and hight.. all you gotta do is cut the shifter REAL low with a dremel.. then get someone to weld the little piece of threading that is located on the top the the shifter itself and weld it back on.. thus still allowing you to use the stock **** but have it MADDD LOW... pics COMMIN SOON
EDIT: don cut too low or the plastic ring on the shift boot will not sit right.... it will be pushin against the BEND of the shifter downlow.
Old Oct 1, 2002
Chapobapo's Avatar
Chapobapo is an unknown quantity at this point
Let me just make sure i got this right... for our civics, we need a short shifter and an adapter too right?
Old Oct 1, 2002
Grey's Avatar
DIY King
You don't NEED anything. Get the Revo Technica SS. It reduces shifter height and it relocates the cable attachment pivot point. Both of which reduce the throw. I have it and it's the bomb!
Old Oct 1, 2002
OsOBooSTeD's Avatar
OsOBaNNeD
Nah Grey. you are right that is all u really need... BUT when I bought my civic (nov1,2000) there werent any shift kits ... ALL i found was the solo adapter.. and i had to IMPROVISE so i cut it too. sucked for me i guess cause now u can buy the WHOLE shifting platform. [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Oct 1, 2002
Grey's Avatar
DIY King
I had the Solo SS adapter at first too. I sold it though and I got the Revo Technica SS.
Old Oct 1, 2002
DarkCivic's Avatar
DarkCivic is an unknown quantity at this point
He he- I have Grey's old Solo SS adapter and I cut the shifter with a hacksaw- both improved my throws. I also have a Velox shift **** that sits pretty low itself.
Old Oct 2, 2002
Chapobapo's Avatar
Quote
[hr]Originally posted by: Grey
You don't NEED anything. Get the Revo Technica SS. It reduces shifter height and it relocates the cable attachment pivot point. Both of which reduce the throw. I have it and it's the bomb! [hr]
thanks grey. was the revo hard to install? how much does it run for usually?
Old Oct 2, 2002
Grey's Avatar
DIY King
Not too hard. The toughest part was pulling up on the center console piece around the e-brake to get it off. That piece is hard to pull up. Besides that you just follow the directions. Well, wait. There's one more thing that's hard to do. There's this one plastic thing on the shifter that you have to twist off. I broke mine. I had to superglue it back on.
Get them off of Ebay. That's where I got mine. They sell for as little as $75 now. I got mine for $96 shipped.
Old Oct 2, 2002
Chapobapo's Avatar
coo, thanx grey [IMG]i/expressions/beer_yum.gif[/IMG]
Old Oct 2, 2002
Grey's Avatar
DIY King
When you get to the tough parts let me know, I'll send you some good links to check out that will help.
Old Oct 3, 2002
Chapobapo's Avatar
thanks alot grey, ill do that by the way good job on the trunk diy.
GolNat
Nov 27, 2018 03:32 PM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
AffliictiioN
Sep 16, 2015 02:21 PM
Jrosa
Sep 14, 2015 08:24 PM
