any advantage
Old Sep 12, 2002
bake's Avatar
bake is an unknown quantity at this point
any advantage
in have 3 subs compared to having 2......any differences in spl or sound quality or is it good just for looks
Old Sep 13, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
every sub adds 3db of sound
every time you double the power it adds 3 db
Old Sep 13, 2002
LudlamTheory's Avatar
i boogie for the raindrops
to those of you not knowing the standard of 3 db's, its a doubling of the pressure... you wont hear it twice as loud, but the pressure will be twice as high, but thats saying that you have 2 subs, each being pushed by 300w, and add another sub, and put another 300 w to it... if you just split your existing power the increase in spl wont be as high, but you may see less distortion due to the fact that you'll have to push it less to get to the same level of bass..
Old Sep 15, 2002
WhiteRabbit's Avatar
Quote
[hr]Originally posted by: Subrage
every time you double the power it adds 3 db[hr]
so if your running 30 10" with 30,000 watts of power hitting 170 dB, and add one more 10" and another killowatt, youll meter at 173.
in terms of output, every time you double the number of woofers in your system (1 to 2, 2 to 4, 3 to 6, 4 to 8) AND double yoru power, you double your output. on an SPL meter this will translate to a 6 dB increase, assuming 100% efficiency.
the difference between 2 and three woofers all depends on box design, and the power you have available. I personally wouldnt consider getting an additional woofer an upgrade if you are currently running two. if you are just planning at this point, then getting a trio of woofers may be worth considering, but just adding a third if you already have two would mean rebuilding the box and maybe purchasing a new amp, which may or may not be in your best intrests.
certainly not JUST for looks, but like everything, it has a piece of it too. do a search, and youll find one of mohawk and my threads about output and energy, and the benifits and gains from various power and subwoofer combinations.
bowie
Jan 21, 2018 09:29 PM
carid
Nov 7, 2015 01:46 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
SidCivic
Sep 12, 2015 05:28 PM
WhiteRabbit
Jun 25, 2002 02:10 PM
